Trickflow/TEA flow #s
Thanks to the fantastic service from TEA, my new Trickflow 215s arrived today, and they look great. Less than 2 weeks from the time I ordered a custom setup, to delivery. WOW!. Anyway, here's the flow #s.
Lift Intake Ex.
.200 140.4 118.5
.300 219 180.4
.400 260.4 231.4
.500 301.4 254.3
.550 319.9 260.8
.600 332.1 264.2
Lift Intake Ex.
.200 140.4 118.5
.300 219 180.4
.400 260.4 231.4
.500 301.4 254.3
.550 319.9 260.8
.600 332.1 264.2
Originally Posted by Hardtop
Nice, what cam are you going to run with them?
Bruce
Bruce
Crane 228/232 112+5, this is a street only setup, at least that was the plan. Stock '02 ZO6 with headers, and FAST90.
You may want to go a little smaller on the cam for a street only setup (if you dont already have that cam). With the combination you have (Fast 90 TFS heads) you are going to be well over 510HP @ the flywheel. With a 216 ish cam you will trade some hp for some low end torque. If you already have the cam slide it in and hold on!
The thing I'm going for is midrange. Car's so light that traction is non-existant until the top of 2nd now, and after the H/C... Really want it to pull like a mother from 60-150. Not a DD, but with the low first gear of the M12, it's like a MN6 with 3.90s. Probably need to find a real traction tire that's available in 19".
Yeah, John, planning on doing the install in the garage, and after a couple of break-in miles and an oil change, take it over to a tuner by Portland.(about three hours down the road) He uses a Mustang dyno, and has a real good rep. Some time after that I'll take it to the place I got a baseline (w/headers) that uses a Dynojet, so I'll have a comparison. Another guy just down the street from me has a Dynapak, and might even try that one for laughs.
[QUOTE=exSSer]The thing I'm going for is midrange. Car's so light that traction is non-existant until the top of 2nd now, and after the H/C... Really want it to pull like a mother from 60-150. Not a DD, but with the low first gear of the M12, it's like a MN6 with 3.90s. Probably need to find a real traction tire that's available in 19".QUOTE]
My car is the same way, and I agree about the mid range. I think that head and cam combo will work great. Good luck, and post your results.
Bruce
Bruce
I must disagree.
He already has a Z06 cam swaping to a 216ish cam would be a waste.
Probally wouldn't even gain 15 RWHP.
Stick with the cam you have it should work.
The +5 is a bit overkill but the cam should still be very good.
Originally Posted by Brian Tooley
Once upon a time I would have called BS on flow numbers like those.
Good luck and keep us posted
High quality TFS heads pics here.......
https://ls1tech.com/forums/showthrea...hlight=Jnorris
this customer just went 10's on motor in the Alabama heat!
Head has 64cc chambers, and more piston to valve clearance then a stock LS1 head
Lift Intake Ex.
.200 140.4 118.5
.300 219 180.4
.400 260.4 231.4
.500 301.4 254.3
.550 319.9 260.8
.600 332.1 264.2
Lift Intake Ex.
.200 140.4 118.5
.300 219 180.4
.400 260.4 231.4
.500 301.4 254.3
.550 319.9 260.8
.600 332.1 264.2
It's all about comprehension. Hence the "Once upon a time" part of that sentence. Meaning the heads flow more air then they have a right to, more then I would have thought possible on a 3.90 bore.
Originally Posted by Cobraeater
Did these numbers come from TEA's flowbench?
I would assume so. They take the raw castings, do all the machine work, and final assembly, and then ship to the customer.
