Trickflow/TEA flow #s
Old Jul 12, 2006 | 06:28 PM
exSSer's Avatar
Default Trickflow/TEA flow #s
Thanks to the fantastic service from TEA, my new Trickflow 215s arrived today, and they look great. Less than 2 weeks from the time I ordered a custom setup, to delivery. WOW!. Anyway, here's the flow #s.
Lift Intake Ex.
.200 140.4 118.5
.300 219 180.4
.400 260.4 231.4
.500 301.4 254.3
.550 319.9 260.8
.600 332.1 264.2
Old Jul 12, 2006 | 06:45 PM
Hardtop's Avatar
Nice, what cam are you going to run with them?
Bruce
Old Jul 12, 2006 | 07:03 PM
exSSer's Avatar
Bruce
Crane 228/232 112+5, this is a street only setup, at least that was the plan. Stock '02 ZO6 with headers, and FAST90.
Old Jul 12, 2006 | 07:36 PM
LsReddog's Avatar
You may want to go a little smaller on the cam for a street only setup (if you dont already have that cam). With the combination you have (Fast 90 TFS heads) you are going to be well over 510HP @ the flywheel. With a 216 ish cam you will trade some hp for some low end torque. If you already have the cam slide it in and hold on!
Old Jul 12, 2006 | 09:55 PM
JNorris's Avatar
Moderator
Great numbers! Are you going to dyno it after the install?
John
Old Jul 12, 2006 | 09:57 PM
exSSer's Avatar
The thing I'm going for is midrange. Car's so light that traction is non-existant until the top of 2nd now, and after the H/C... Really want it to pull like a mother from 60-150. Not a DD, but with the low first gear of the M12, it's like a MN6 with 3.90s. Probably need to find a real traction tire that's available in 19".
Yeah, John, planning on doing the install in the garage, and after a couple of break-in miles and an oil change, take it over to a tuner by Portland.(about three hours down the road) He uses a Mustang dyno, and has a real good rep. Some time after that I'll take it to the place I got a baseline (w/headers) that uses a Dynojet, so I'll have a comparison. Another guy just down the street from me has a Dynapak, and might even try that one for laughs.
Old Jul 13, 2006 | 06:52 AM
Hardtop's Avatar
[QUOTE=exSSer]The thing I'm going for is midrange. Car's so light that traction is non-existant until the top of 2nd now, and after the H/C... Really want it to pull like a mother from 60-150. Not a DD, but with the low first gear of the M12, it's like a MN6 with 3.90s. Probably need to find a real traction tire that's available in 19".QUOTE]
My car is the same way, and I agree about the mid range. I think that head and cam combo will work great. Good luck, and post your results.
Bruce
Old Jul 14, 2006 | 09:05 AM
Brian Tooley Racing's Avatar
Once upon a time I would have called BS on flow numbers like those.
Good luck and keep us posted
Old Jul 14, 2006 | 11:46 AM
TAF Motorsports's Avatar
Old Jul 17, 2006 | 01:05 PM
Hardtop's Avatar
Any updates?
Bruce
Old Jul 17, 2006 | 07:30 PM
JZ'sTA's Avatar
I must disagree.
He already has a Z06 cam swaping to a 216ish cam would be a waste.
Probally wouldn't even gain 15 RWHP.
Stick with the cam you have it should work.
The +5 is a bit overkill but the cam should still be very good.
Old Jul 17, 2006 | 08:44 PM
Bluewire's Avatar
Originally Posted by TAF Motorsports
Old Jul 17, 2006 | 08:49 PM
xfactor_pitbulls's Avatar
You would call BS on your own heads? Hear voices behind you much Brian?
Old Jul 18, 2006 | 02:50 PM
It's all about comprehension. Hence the "Once upon a time" part of that sentence. Meaning the heads flow more air then they have a right to, more then I would have thought possible on a 3.90 bore.
Old Jul 18, 2006 | 03:15 PM
Xtnct00WS6's Avatar
wow! Post some detailed pics dude! What is the combustion chamber size?
Old Jul 18, 2006 | 04:08 PM
High quality TFS heads pics here.......
https://ls1tech.com/forums/showthrea...hlight=Jnorris
this customer just went 10's on motor in the Alabama heat!
Head has 64cc chambers, and more piston to valve clearance then a stock LS1 head
Old Jul 18, 2006 | 04:56 PM
Xtnct00WS6's Avatar
Those are dead sexy!! Anyone have closeups of the intake?
Old Jul 18, 2006 | 06:41 PM
slmdLS1's Avatar
Lift Intake Ex.
.200 140.4 118.5
.300 219 180.4
.400 260.4 231.4
.500 301.4 254.3
.550 319.9 260.8
.600 332.1 264.2
yikes!
Old Jul 20, 2006 | 02:25 AM
Cobraeater's Avatar
Question
Did these numbers come from TEA's flowbench?
Old Jul 20, 2006 | 02:51 PM
exSSer's Avatar
I would assume so. They take the raw castings, do all the machine work, and final assembly, and then ship to the customer.
