lots of parts of sale in mansfield
Old 07-13-2006, 01:15 PM
95 N2OT/A's Avatar
Default lots of parts of sale in mansfield
i'm about 30 mi south of dallas
i've parted out several cars and have lots of parts lying around here's a list of what i found so far but there are many more to come
complete trans am steering column with air bag and steering wheel with volumn controls- $150
complete 98 camaro steering column with air bag and steering wheel- $150
93-96 camaro gauge cluster bezel in ebony- $20
charcole sail panels- $40 for the pair
98-02 A/C control panel- $20
98-02 headlight control panel- $20
98 camaro z28 stock injectors with only 42k miles- $50
hatch weather strip (does not leak)-$10
cig lighters in gray and black- $5 each
Vats bypass module- $15
camaro z28 3rd brake light- $10
hatch release button- $5
interior dome lights in charcole and tan- $10 each
LS1 camaro tail lights (passnger one has a small crack in it but you have to look for it)- $80 for the pair
complete camaro hatch in red- $60
camaro spoiler with 3rd brake light in white- $25
c-pillars in ebony- $10
ls1 rockers with only 42k miles-$80
LS1 rocker guides-$20
98 LS1 fuel rail assembly- $50
complete set or tan leather seats out of a 98 camaro (drivers seat had oil spilt on it and the rear seat back has a 2-in rip in it)-$100 for the set
drivers camaro doors one is red the other is white- $80 each
passenger trans am door in a non-factory metalic silver color- $80
red camaro z28 rear bumper with a few chips in the paint-$25
red rear beager panel with z28- $25
trans am rear bumper in a non-factory metalic silver color- $60
323 3-channel stock 10 bolt rearend with 76k miles- $250
ls1 front brake upgrade (includes ls1 calipers, spindels, and rotors) $200
ls1 k-member-$60
Lt1 k-member- $50
ls1 fuel sending unit with stock fuel pump- $80
lt1 fuel sending unit with stock fuel pump- $80
lt1 fuel sending unit with out fuel pump- $60
lt1 fuel tank- $10
lt1 3-channel abs module- $30
lt1 4-channel abs module- $40
ls1 3-channel abs module- $50
ls1 steering rack and pinion- $40
ac condinser- $20
LT1 non-ram air firebird/trans am hood in a non-factory metalic silver color- $40
washer fluid resivor with pump- $10
brake booster- $20
LS1 PCM holder bracket- $10
LT1 starter with 76k miles- $60
LT1 motor mounts- $40
LS1 motor mounts-$50
LS1 front strut assemblies with only 42k miles- $80 pair
LS1 lower a-arms- $30 pair
LS1 upper a-arms- $10 pair
LT1 lower a-arms- $20 pair
LT1 upper a-arms- $10 pair
98 LS1 MAF- $40
LT1 front brake calipers- $40 pair
horn assembly- $20
drivers side tan sunvisor in perfect condition- $15
tan hard top headliner in perfect condition- $40
M6 pedal assembly out of a 98 camaro with sensors- $60
complete set of tan seatbelts- $40
fuel lines for lt1 and ls1- make offer
93-96 camaro glove box in ebony- $20
LT1 power steering resivor with cap- $15
LS1 e-brake cables- $30 set
e-brake handle- $25
drivers air bag out of a 96 trans am (i think it will work on any 95-97 firebird or trans am)- $50
rear view mirror- $10
factory amp out of a 97 trans am- $40
several front and rear sway bars out of a 96 camaro z28, 97 trans am, and 98 camaro z28- $5 each
global west ADJ PHB- $100
tan leather interior door panels (the're kinda dirty)- $30 for the pair
that's all i can think of right now but i'm sure i'll add stuff a later
all prices are OBO and plus shipping if needed
i would prefer local pickup
check my feedback if you feel the need to verify i'm an honest person
thanks
robbie
Old 07-13-2006, 02:11 PM
1936FordPU's Avatar
Whats the best you can do on the LS1 motor mounts?
Old 07-13-2006, 02:12 PM
95 N2OT/A's Avatar
PM me an offer
thanks
robbie
Old 07-13-2006, 03:15 PM
SUTTERERMAN85's Avatar
you got a good back camaro bumper? dont car the color. no dents or cracks though pm me. thanks
nick
Old 07-13-2006, 03:18 PM
White 96LT1's Avatar
do you have the wiring harness and ECM for a 96 Trans am
Old 07-13-2006, 03:19 PM
i am a dumbass...helps to read all of the post...sorry i want the tail panel and bumper. take $40 for the 2? if so pm me your address and when i can come get it.
nick
Old 07-13-2006, 06:02 PM
95 N2OT/A's Avatar
sorry no wireing harness or pcm for the 96
thanks
robbie
Old 07-13-2006, 06:13 PM
redaddiction's Avatar
Bump for a good seller.
Old 07-13-2006, 06:27 PM
Charlie Hustle's Avatar
how many miles on the upper and lower ls1 a arms? pics?
Old 07-13-2006, 07:01 PM
95 N2OT/A's Avatar
42k miles are on all the ls parts
sorry i cannot get you pics at this time but i assure you they are in good working condition
thanks
robbie
Old 07-13-2006, 09:13 PM
blue00WS6's Avatar
Rack and Pinion. Anything wrong with it?? Does it leak? Is it bent?? Let me know ASAP. If everything is good, I can pick it up this weekend!!
James
Old 07-13-2006, 09:16 PM
2001 White Ws6's Avatar
Damn man are you runnin a chop shop?
Old 07-13-2006, 10:36 PM
95 N2OT/A's Avatar
rack and pinion is in perfect condition. PM sent
thanks
robbie
Old 07-13-2006, 10:43 PM
ramairracer's Avatar
sorry maybe posted or not but whats the best you can do on the ta rear bumper, ls1 front hub if you got it, and maybe pass 98+ fender,
Old 07-13-2006, 11:32 PM
95 N2OT/A's Avatar
sorry no ls1 front hub or pass 98+ fender
thanks
robbie
Old 07-13-2006, 11:59 PM
mitchntx's Avatar
I've got a hub, if Robbie doesn't.
PM me ...
Old 07-14-2006, 01:07 AM
MESS's Avatar
You still have those 3.42 gears laying around in your garage?????
Old 07-14-2006, 09:34 AM
blue00WS6's Avatar
thanks
robbie
I tried to reply to your PM, but your box is full. I will give you a call a lil later this afternoon on my lunch break. If I don't get in touch with you on my lunch, I will make the call tonight when I get off work.
James
Old 07-14-2006, 11:27 AM
95 N2OT/A's Avatar
yes i do but i think i'm going to hold on to them just incase something happens to mine. i brake **** all the time
thanks
robbie
Old 07-14-2006, 11:28 AM
K9Kev's Avatar
PM Sent on hatch seal...and misc other parts.
