228/228 588/588 comp cam
Originally Posted by Eatinstang4life
Does anyone have or know about this cam, I heard it is a great street cam that makes good power?Any info about this cam would be great. How muchpower you think I could get with this cam? My current mods are in sig. Thanks
I'm running the 228/230 Comp XER on a 112+2. Great cam, good lope. This is my fourth cam, my only regret is I should have gone bigger. However I might add that little by little my car is turning into a strip car only. Iron 408 this fall.
I have a custom comp also> could be a daily driver,01 ws6,silver,3400 stall,B&M trans cooler,DTS 12 bolt ,3:73,DTS support cover,complete BMR chrome moly suspension bolts on's including panhard bar,adjustable torque arm,tubular control arms,driveshaft loop,strut bar,optima red top battery,k&n,slp lid,bg ram air mod,Mac headers,off road y pipe,magnflow catback,MSD wires,NGK plugs,smooth bellows,slp mass air flow,throttle body coolant by pass,160 stat,
2.02 1.575 manly racemaster valves with fully polished and ported heads Trend Fully hardend 7.350 pushrods, COMP TI retainers, Dual Valve spring's
custom comp 228 236 588 578 114 ,ARP hardware.420hp/380tq
I have this cam in my car and it's a daily driver. I like it, No problems, makes good power. 6-speed cam only cars with this cam generally see 370-400 rwhp depending on which bolt-ons they have.
I had a set of LS6 heads that I gave to my tuner, but bought another pair (bare 243 head) with a stage 1 port job to 215cc/80cc for $770.00 on ebay, a brand new casting. (Pro-flo) I took them to the next level cleaning them up using a drummel tool with a speedometer cable and wand to get into the tight spaces. I dropped the floor of the intake port and cleaned up the runners and the exhaust runners, but left the D shaped exhaust ports almost alone for good outlet velocity. I then polished everything using buff *****. All took about 10 hours. I took them down to my friend's machine shop (Powerhouse, E. Taunton Ma.) and he milled them to 62cc for a resulting 11.0:1 compression. So, with little invested I'm very happy with the results. It was an easy decision for the FAST 90 intake and 90mm throttlebody hehe. Got the intake on ebay too, right out of the box and port mached the intake port to the new. Texas-speed.com for the LS2/LS7 throttlebody a great deal, GM wanted almost twice as much. I reused my LS6 sodium filled valves lol!
I've got the same cam. I am very happy with the set-up. Looking to add some TSP LS6 heads soon.
The cam is a good daily driver with good mid range power. It has a nice lope and a good ilde with tune.
Originally Posted by Toasty
I'm looking for 430-440hp and mid-11's....sounds like I could hit that with this 228 and the TSP LS6 heads.
What do you think?
What do you think?
Originally Posted by cantdrv65
My car makes 450rwhp/410rwtq with that cam on a 114 + 4....TSP LS6 heads.
Do you really think you'll get more that 40-45 HP on that cam and 40-50 HP on those heads ? I dont
IF you have the 90/90 set up, you'll get 15+ more over the LS6 manifold
