Guys with lowered trans ams, question.
Do you have any trouble when it comes to taking your car to a shop and getting it on a lift, or even getting a jack under it to do oil changes because of the added ground effects on the TAs?
I know on my friends camaro its no problem but he has no ground effects.
i had some problems jacking up my 02 trans am that was lowered 2", what i would have to do is use the jack that comes with the vehicle to raise it up a few inches and then use the big jack. But when i put 18's on it i was able to get the 3 ton under it easily.
Shops have problems with our cars stock - I avoid a shop at all costs. I am anble to get a low profile floor jack under 1 side then I use another floor jack to get to the pumpkin or the K-member.
Originally Posted by ChevyChad
When taking to a shop with a lift, they just put wooden blocks under the ramps so it can make it up onto the lift.
