Ordered 15x10 wheels with 5" backspace...how much to narrow rear?
I'm putting these on but want the tires tucked in as far as they'll go with a small diameter spring, offset LCAs, and minitubs. I'll be running a 29.5x10.5x15 non-w tire
How much should I narrow 3.5"/side?
Originally Posted by LOnSLO
Mine is narrowed 3.25" per side. Any more and I would need mini tubs. I would go for the 3.5" or more (can't remember if you have minitubs or not).
Question will be will 3.75" be too much?
Originally Posted by Elite_Hot_Rod
3" is as far as I would go, anymore than that and you will need mini tubs.
I WILL HAVE MINITUBS
Originally Posted by Tom the roofer
3" per side here. 5.125" BS. You will need to mini tub to do this. Are you going to mini tub?
The only area I had to address was my lower relocation brakets. I am running a custom 8.8 and to run a 5 1/2" backspace with setup, I have to cut the bottom hole off of the lower relocation bracket. This is with 3" per side of back spacing. That is why I recommended 3 1/2". I am also minitubbed
I DID 3.5" PER SIDE and a 5" back space wheel...no issues, but I can't go any wider without doing some pretty creative relocations. This is min-tubbed and offset arms and small springs
How close are you to your suspension components...could you have tucked them in any further?
I have about 1/2" clearance from the offset LCAs with a 12.5" sidewall tire. I could go to a 13.1" sidewall and still have a little room left. I have 2.5" springs and they have plenty of clearance.
