ARP head bolts or head studs???
Old 07-18-2006, 02:24 PM
2002/Black/SS's Avatar
Default ARP head bolts or head studs???
can i only get the studs if im going to install the heads with the engine out of the car?? if this is true i have to get the bolts right?
Old 07-18-2006, 04:17 PM
Slo_240sx's Avatar
You can use both. The studs should be the same length as the bolts. An out of car build people put the studs in first. Inside an F body, I would imagine its impossible so you put the head on then screw the stud in afterwards then put the nut on. Does anyone know if there is a big difference in the bolts and studs? The studs are like 80 bucks more I believe.
-Alex
Old 07-18-2006, 04:22 PM
viewsonic's Avatar
-Alex
This method would defeat the purpose of studs...
If you are going to do that then why not just get bolts?
Studs are supposed to be installed once in the block and then left along... This prevents the block "from getting messed up" from not having to constanly bolt and on bolt stuff...
If you were going to undo the studs everytime you did a head swap then the studs have no advantage over bolts...
Head studs are really best if you plan to take your heads off a few times anyway....
Old 07-18-2006, 04:28 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
FI guys should probably run studs...I am sure they see their fair share of blown head gaskets from time to time.
Old 07-18-2006, 04:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I don't see why you don't just get the GM stock replacement bolts and call it a $100 cheaper day.
Old 07-18-2006, 04:36 PM
Joel_SS's Avatar
I got the ARP head bolts.. Good thing about them is they can be re-used.. Torque to 70 lbs and call it a day..
Old 07-18-2006, 04:38 PM
viewsonic's Avatar
I heard they do not "hold" any better than arp bolts?
Makes sense since they are virtually the same thing when all bolted up....
ЯєŧąяĐ Єl¡m¡иąŧøя ™
How is your motor holding up?
Old 07-18-2006, 04:40 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
But if you are taking your heads off every 5 days because of a blown head gasket it does make sense. I wasnt talking about just for having a 220,000 PSI rating. Just for ease of changing.
Old 07-18-2006, 04:42 PM
Joel_SS's Avatar
Great 1000 miles and no measuredable oil burnage! But my converts lock up clutch just took a ****.
Old 07-18-2006, 04:43 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
*ringing* Hello? Is this the TCI hotline?
Old 07-18-2006, 04:46 PM
Xtnct00WS6's Avatar
I don't see FI in your sig, so I'd recommend ARP bolts.
You'll thank yourself during the install for buying the ARP bolts over the GM stockers. TRUST ME! The procedure for tightening the GM bolts is a real pain in the ***. I also found that the ARP's have a slightly smaller head than the stockers which gives you that tiney extra bit of clearance to get them in the back few boltholes with ease. I think it was the last head bolt on the bottom, on the passanger side that was the hardest to get out. The ARP bolt slid right in though.
Old 07-18-2006, 04:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Either way man. Doesnt sound like studs are a good option for you.
Old 07-18-2006, 04:54 PM
Joel_SS's Avatar
If you go with the ARP bolts make sure you get some of the assembly lube with it! That will make it easy to torque down and you reading will be alot more accurate!
Old 07-18-2006, 04:55 PM
Joel_SS's Avatar
More like, take this POS converter.. and then I am gonna call PI and order what I should have in the first place..
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is the white crap right?
Old 07-18-2006, 04:56 PM
Joel_SS's Avatar
Nope grayish/silver...
Old 07-18-2006, 05:04 PM
viewsonic's Avatar
ahhh, I misunderstood.
Yup, not having to clean bolt holes is a big plus.
P.S. You can use motor oil on the bolts instead of ARP lube
Old 07-18-2006, 05:06 PM
Joel_SS's Avatar
True, but you must use the correct TQ rating. ARP has diffrent specs depending on the lube you use.
Old 07-18-2006, 06:12 PM
where do i get the lube? also do the bolts come with insturctions for the torquing procedure?
