Should the intake ports on my heads look like this??? (pic inside)
Old 07-19-2006, 03:09 PM
00Vette's Avatar
Default Should the intake ports on my heads look like this??? (pic inside)
I'm in the middle of an LS1 to LS6 intake swap and noticed that there were a lot of what looks like burnt oil build up on my intake ports......
Is this normal?
Has anyone else came accross this in there days of LSX's???
This is my first time removing the intake manifold!
Attached Thumbnails Should the intake ports on my heads look like this??? (pic inside)-dsc04012.jpg
Old 07-19-2006, 03:15 PM
bmfcamaro's Avatar
i would say ya. i would think that its from the oil that gets in the intake from the pcv. i took mine off and i believe they looked the same way.
Old 07-19-2006, 03:17 PM
Layn_Low_247's Avatar
Is this normal?
Looks normal, but I'd consider cleaning them up, and swapping the valve train out while there off. How many miles on the heads Jon?
Old 07-19-2006, 03:19 PM
00Vette's Avatar
a whole lot! I'd say about 35,000 at least! I'm definately going to clean them up the best I can.
Old 07-19-2006, 03:52 PM
NemeSS's Avatar
use some of the oven cleaner stuff in a can, that stuff rips all of that grime
off the aluminum
Old 07-19-2006, 04:24 PM
GuitsBoy's Avatar
Yeah, my stock heads good super gross.
Old 07-19-2006, 04:32 PM
pro1955's Avatar
The LS-1 in those years did not have very good PCV systems, alot of guys run catch cans to help the problem, you here of people complaining about oil in the intake manifolds all the time on LS-1's. If you run your car hard the problem only gets worse.
Old 07-19-2006, 07:03 PM
00Vette's Avatar
Yeah......I run her pretty hard too!
I'll look into a catch can. Is it hard to do?
Old 07-20-2006, 02:13 AM
CATDIESEL's Avatar
EGR will contribute also , Mine looked same way , 45k miles
Quick Reply: Should the intake ports on my heads look like this??? (pic inside)
