Sponsored by: DashLynx
Painting ground effects
Old 07-20-2006, 02:44 AM
Camaro Ryder KV's Avatar
Default Painting ground effects
Hey guys, i have a question for you all, i am going to be painting ground effects for my camaro and i know i need to sand and prime, but is the stuff at autozone or pep boys good? what type of black should i get, flat or glossy, and if i get flat black, what kind of clear should i get? any input would be greatly appreciated.
thanks
Kevin
Old 07-20-2006, 07:09 PM
anyone?
Old 07-20-2006, 07:14 PM
sills1's Avatar
Black is one of the hardest colors to paint. Have a body shop do it for you and save yourself time and alot of headache.
Old 07-21-2006, 12:39 AM
i knew black would be hard, but i want to try to tackle it myself. Got any tips?
Old 07-21-2006, 02:48 AM
ttt.....
Old 07-21-2006, 03:17 AM
blown 346's Avatar
I wouldnt use any type of rattele can on large body components like GFX.
To get a decent job I agree to get it painted. Or you could buy your own paint gun at lowes etc and get some decent paint, clear and thiner and try it yourself. That would be your best bet.
Old 07-21-2006, 05:55 AM
FredoCamaro's Avatar
Uh oh, better get Mayco
Old 07-21-2006, 06:05 AM
transambandit's Avatar
find an auto paint shop and get your supplies from them, they have all the sand paper you need and can scan your paint to match colors, paint fades over time. I did a quarterpanel in black and the hardest part is not getting it to run, other than that its not all that difficult.
Old 07-21-2006, 11:24 AM
Awesome advise guys, could i use menards as an auto paint store?
Old 07-21-2006, 06:03 PM
kingb's Avatar
is it fiberglass or urathane.? this is very important and every ground effects kit i have ever painted , if it wasn't factory it has been junk
Old 07-25-2006, 05:20 PM
the sides and back are factory and the front is rksport (urathane)
can anyone do a write up for me?
Please
Thanks
Kevin
Old 07-25-2006, 11:07 PM
ttttttt
Old 07-25-2006, 11:56 PM
any help would be appreciated, i am starting in 2 days
Old 07-26-2006, 12:06 AM
kpowr82's Avatar
Go to an auto paint supply store and get a color match using PPG paints. if you're gonna spray yourself you'll need at least a 35 gallon air compressor (50+ would be better, but since you're painting relatively small pieces, a 35 gallon will do). Get yourself an HVLP gun (High volume, Low pressure; creates less overspray and less wasted product with excellent transfer efficiency).
You'll need Primer, Reducer, Hardener, Basecoat, and clearcoat to do it right. You also may want to invest in a flex additive, especially for the long side pieces. This will help to prevent chipping or stress cracking the paint during installation. As far as the actual procedure is concerned, there are many good write-ups online as well as good beginners guids at Barnes and Noble or Borders.
Don't be scared. With the proper tools and materials it's a very easy hobby to pickup but a very difficult one to master.
Old 07-26-2006, 12:48 AM
thanks buddy
Quick Reply: Painting ground effects
