Texas Speed duals...
The muffler option with the texas speed dual setup are dynomax bullets, sweet thunder, and moroso spiral flows. Im going to order the duals, but does anyone have any sound clips or opinions on what mufflers are good to go with? Thanks.
Ls1sounds is nice but sometimes video dont tell the whole story as far as the sound of it, the spiralflows sound good. If you get a sound clip scott send me a pm. Thanks guys.
Bullets flow the best if that matters to you.. The spiral flows are the quietest, which isnt very quiet... The Sweet Thunders imho sound the best, but they reduce to 2 1/2 pipe in the middle.. If you plan on having tons of HP, the bullets are best for you.. if youre not so worried about getting all the power you can, get one of the other two.. either way, any setup will flow better than a y-pipe setup..
I have the TSP's and have actually tried all three "muffler" options. The bullets are just Nasty in a good way. Very unrefined, lod and just scream at wot. The exhaust sounds all over the place. The sweet thunders clean up the sound a little, but still have that muscle car rumble with some added smoothness. They scream up top and have a controlled sound. The spiral flows are the smoothest sounding, less loud than the others, but loud nontheless. It has the most controlled sound, and sounds very similar to a Mustang with flows. I ended up staying with the sweet thunders, because that had the best mix of loud, sound quality and old school burrble. And dont worry about flowing from the 3 into the 2.5. Unless you are running a big cube motor or fi, i wouldnt worry, and even then 2.5 all around td's are enough for most.
