? AFR Stage 3 205's w/ TR224 cam?
Old 07-23-2006, 01:31 PM
Moderator
davered00ss's Avatar
Default ? AFR Stage 3 205's w/ TR224 cam?
I have a chance to get a set of Stage 3 ported AFR hedas from TTP for a good price. They are milled.030, Matt said the CR would be about 10.9. My question is are these heads wrong for a small cam. I am running a TR224. I don't want to lose any low end TQ, or tip in/throttle response. Anything I should be concerned about? P/V clearance on a stock block?
Thanks,
Dave
Old 07-23-2006, 02:20 PM
The1N_only's Avatar
you shouldnt have any P/V clearance problems with that cam... the TR224 is a tried and true cam. with a good tune you should make around 400 rwhp with supporting mods and be pretty tame as far as driveability goes
Old 07-23-2006, 02:25 PM
dug
dug's Avatar
Id get the same cam with x-er lobes. The added lift will help take advantage high airflow of the heads.
Old 07-23-2006, 02:55 PM
LS1 Tech Administrator
Patrick G's Avatar
You should be well into the 400s with that cam and AFR heads. The power in my signature is made with only a 224/228 cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 07-23-2006, 05:23 PM
Moderator
I know I will be over the 400 mark, the question is on the Stage 3 port job. Will the porting on the AFR's effect my low end Tq, and Throttle response? I wanted to know if stage 3 ported AFR's are wrong for a small cam. (that I already have in the car)
Old 07-23-2006, 05:51 PM
LS1Tech Sponsor
Slowhawk's Avatar
I wouldn't run Stage 3's with that Cam. Standard 205's milled .030 will do.
Old 07-23-2006, 05:54 PM
Moderator
Don, The price is just great on a used set he has. Is there a downside on the Stage 3's for my set up?
Old 07-23-2006, 10:36 PM
eamador11's Avatar
your 224 cam may not keep up with the extra air flow the heads are giving you. thus leaving power on the table. h/c setups means the cam must match the head flow to get a killer result. sound slike you need to up the cam profile. my .02
Old 07-23-2006, 10:45 PM
Studytime's Avatar
I would imagine you would loose some low-end and throttle response. It seems like you're a little worried about this, rightly so.
What can it hurt to try them? Are you doing the install yourself? If they really are a killer deal, buy them and try them. If you are not happy with them, trade them off or sale them.
You could also build a stroker to help your parts 'mismatch'.
Ben T.
Old 07-23-2006, 10:59 PM
Studytime's Avatar
Oh, let me add this.
Run your DCR at the limit as it will help low-speed output. Just keep in mind if you're going with a bigger cam, you'll have to flycut later on.
Ben T.
Old 07-25-2006, 05:39 AM
LS1Tech Sponsor
Slowhawk's Avatar
Yes,that is why I said "I would not recomend them".
Get the TSP PRC small runner head (200cc).Those will work and make sure compression is 10.8-1 or more.
Someday you WILL listen
Old 07-25-2006, 05:40 AM
LS1Tech Sponsor
Slowhawk's Avatar
Yes,they are too big and will hurt down low power.Get the TSP 200cc heads.
Quick Reply: ? AFR Stage 3 205's w/ TR224 cam?
