Thunder Racing CheaTR package
Old 07-27-2006, 09:18 PM
noxiouSS's Avatar
Default Thunder Racing CheaTR package
Was wondering if anyone has had any experience with this combo. It sounds like everything i want, around 400 at the wheels, stock drivability, and decently priced. But is it to good to be true?
looking for any feed back
Old 07-27-2006, 11:52 PM
NEVR2ND's Avatar
I am not sure what the package includes, but I just installed the cheaTR cam and I like it. It runs within .1 & 1 MPH of my F13 and it idles 100% better.
Old 07-28-2006, 12:10 PM
YankeeVert.'s Avatar
[QUOTE=NEVR2ND]I am not sure what the package includes, but I just installed the cheaTR cam and I like it. It runs within .1 & 1 MPH of my F13 and it idles 100% better.[/QUOTE
I have read that is tough on valve springs.What springs are you running and what kind of life do you expect? Thanks.
Old 07-28-2006, 12:46 PM
PREDATOR-Z's Avatar
It is not more tough than any other fast ramp cam. With 921's properly installed you could see 20>30K miles.
It somewhat depends on the way you drive it also. Like how much you beat on it and if you let the springs warm up to operating temp b-fore hamering it.
Old 07-28-2006, 01:09 PM
SS4Luck's Avatar
not to hi jack the thread but im also considering this package too (the heads and cam)
i know it was designed for stock manifolds but would having basically LTs with pretty much straight piped TDs hurt it?
Old 07-28-2006, 01:22 PM
PREDATOR-Z's Avatar
No, quite the contrary it will put out a few more ponies.
see "designed" for stock manifold is evident by the large split that is exhaust biased to keep the exhaust valve opened longer and facilitate the exit of gases.
Stock cam is designed for stock manifolds, but put on headers and you gain ponies.
Old 07-28-2006, 07:19 PM
noxiouSS's Avatar
that was my next question
Old 07-28-2006, 07:22 PM
noxiouSS's Avatar
there claim of stock idel and drivability is that true? What would be some good upgrades to compliment this package?
i drive it everyday so realiablity is a big factor.
Old 07-28-2006, 08:28 PM
Geoff's Avatar
[QUOTE=YankeeVert.]
I have over 40,000 miles on the same set of springs using the same intake lobe. Hard on valvesprings is just a myth.
Old 07-28-2006, 09:16 PM
NEVR2ND's Avatar
I have Crane dual springs that came on my Patriot Heads when I bought them 3 years ago, at least I think that is the springs they used back then. The CheaTR seams to be ALLOTTTT easier on the springs than the F13 was. The valve train is quieter. I am not planning on changing the springs until I break one or start having valve float.
Old 07-29-2006, 01:59 AM
SS4Luck's Avatar
THis is good to know its not hard on springs... im only 17 and this is pry going to be my graduation/christmas/birthday present lol and i dont feel the need to have to tear apart my motor every 40 or so thousand. my car gets smogged early december so i plan on saying heyi want these and a tune lol and straigh to race prep my car goes lol anyone more care to chime in? haha
Old 07-29-2006, 02:00 AM
SS4Luck's Avatar
p.s. what kinda rpm's does this cam spin? am i going to be shifting at 6K+??
Old 07-29-2006, 02:12 AM
PREDATOR-Z's Avatar
Oh yeah, 6600 minimum to benefit from the powerband.
Now you can shift lower, but you'll be leaving useable power on the table.
Read Patrick G writeup on that cam, it answers the majority of questions.
Old 07-29-2006, 09:33 AM
NEVR2ND's Avatar
Shift light comes on at 6400 but by the time I shift I am usualy at 66-6700.
6800 REV Limiter.
Old 07-29-2006, 02:40 PM
SS4Luck's Avatar
alrite thts what i figured i was just making sure this h/c pakcage is sounding more and more appealing
Old 07-29-2006, 06:13 PM
Threesixes's Avatar
Yep! Im running Patriot heads with my CheatR, but idle and driveability should be the same.
Old 07-30-2006, 12:01 PM
blackhawk J's Avatar
The cheaTR cam is great. I just had thunder racing install it this week. The kit comes with comp cams dual valve springs, titanium retainers, push rods and the nice cam. The idle quality was great, just the slightest lope, barely noticable real stealth. Power is from idle all the way up to 6800 rpms acording to them. So the only real consideration is tweeking the computer to raise the rev limiter to 6800 rpms.
Thunder Racing has my full confidence.
Old 07-30-2006, 12:40 PM
wvutransam's Avatar
^ Your car.....
Awesome ride!
Old 07-31-2006, 08:19 PM
Thanks, another thing I wanted to point out is that even the first time I fired it up there was no valve train noise. I expected at least a little but it is pretty much non existant. I have been testing it around town, loading the engine at low speeds and it really doesnt sound much different from stock. The company really did their homework with this cam.
Old 07-31-2006, 11:20 PM
SS4Luck's Avatar
^^^ good thats exactly what i want to hear... do you ahve power numbers yet?? or sound clips? lol
