Injectors for TF heads and fairly large cam?
I知 still have the stock injectors in my 02 LS1 and I知 curious if I will need high volume injectors to handle TEA Trick Flow heads and a 232 or 237ish cam.
I will also be spraying a 150 wet shot.
The fuel system is in place to support this already (racetronix).
Thanks!
Thanks!
Originally Posted by GMH GTO
Trick Flow vavle springs only good for .600 lift......... WTF? might as well just buy TEA TF heads with dual springs.
SVO?
What about Racetronix #42's - Are SVO's the best?
+1 for SVO30s
They're rated for .650 lift.
I went with 36.5 Racetronic injectors with a 228/232 cam, but I don't plan on spraying it.
