"Planetary gearset noise" any suggestions or ideas?
Old 08-01-2006, 03:35 PM
emarkay's Avatar
Default Loud, unusual tranny noise. Any suggestions or ideas?
Have an unususal noise from the rear of the car (or so I thought). It sounds like a dragging brake or a vacuum leak, but is strictly MPH related (not RPM). The faster one goes, the louder it gets, and in coast or drive, and engine off or on, it stays the same.
By putting the car on a lift, and running and in gear, the sound seems to come from THE MIDDLE OF THE DRIVESHAFT, and it is LOUD! Further inspection sources it to the rear of the transmission. A GM tech who knows these cars said it sounds like the planetary gearset, but it is apparently not. I just had the differential pinion bearing replaced, but can't understand how a once quiet tranny would cause such a noise all at once. A pan inspection showed normal wear debris and no bearing or bushing residue. The car has 86K miles and is stock and not abused.
Aside from the noise, which is rather loud at 60 MPH, everything else is as normal. I don't want to have the tranny exhumed and autopsied unless necessary and the tech suggests living with the noise...
Any ideas, suggestions, similar experiences???
Thanks.
Old 08-01-2006, 03:39 PM
Predator T/A's Avatar
if it is planetary it should go away in 3rd becuase that is direct drive and the planets are locked together
Old 08-02-2006, 10:32 AM
emarkay's Avatar
Geez, thanks. I should have remembered that. Will go take a ride and confirm this in a bit. Thanks again!
MRK
Old 08-02-2006, 12:44 PM
emarkay's Avatar
Nope, it's not the planetary. Noise is in "OD", "D", and "2"... Any ideas?
MRK
Old 08-02-2006, 12:49 PM
i think it is coming from the rear they may not have set the backlash or pinion bearing preload right or maybe just didnt set it up right at all
Old 08-07-2006, 01:50 PM
emarkay's Avatar
The Service manager doesn't feel this is an issue. More info added here:
https://ls1tech.com/forums/showthrea...88#post5311388
Old 08-07-2006, 03:12 PM
i read the link the only thing i can think other than rear would be the rear case bushing or the one inside of the tailshaft.
Old 08-07-2006, 03:14 PM
doesnt sound like plantes becuase 1-2 and 3-4 use different planets and 3 being direct drive 1-2 uses the rear and 3-4 uses the front hard to say man
