Pacesetters installed (pics)
Old 08-02-2006, 02:25 PM
02NBMSLPSS's Avatar
Default Pacesetters installed (pics)
Finally got the headers and ory installed. The sound isnt to bad but it could be better. Ive got the slp dd but its still a little raspy. I could do without the exhaust fumes as well. I think Ill be looking for a catted y now. Clearance is great though. A friend of mine told me pacesetter must of redone the y, because he said they fit a hell of alot better now then they use to. Anybody want to trade their catted y for a brand new ory?
Attached Thumbnails Pacesetters installed (pics)-dsc00566.jpg   Pacesetters installed (pics)-dsc00567.jpg   Pacesetters installed (pics)-dsc00568.jpg   Pacesetters installed (pics)-dsc00570.jpg
Old 08-02-2006, 02:34 PM
LS69TA's Avatar
I guess they either re-designed it or you got really lucky. I haven't heard of many people having good luck with their ORY.
Old 08-02-2006, 02:51 PM
02NBMSLPSS's Avatar
yeah, he said they had to of redesigned them. He has installed plenty of them, said everything bolted right up, not even close to the floorboard.
Old 08-02-2006, 03:19 PM
Traitor's Avatar
My pacesetter y fit good as well. It bangs a bit at WOT in 1st, I'll sort that out later.
Do you think you're getting a good seal with the supplied u-clamps? Like you said, I thought it would sound different (I have the DD as well), I think I'm not getting a good seal with header-y. It sounds a bit like a cut out sounds, it's hard to explain.
Basically it sounds like a cut out kind of (not much noise from the exhaust tips) then around 2800 you can hear an exhaust tone. But under that it sounds like ****, just raw and shitty lol, alot of it coming from under the car. Like I said, it's hard to explain. Not too mention the faint ticking I hear at idle and low rpm.
Like you said, I'm kind of dissapointed in the sound. Above 3K it's good, below that is crap. It might be because I have a leak, I'm not sure.
Old 08-02-2006, 03:21 PM
Ojustracing's Avatar
Hey you might want to get some band clamps. If you happen to bottom out with those clamps you have now! You might do some damage. I would aleast rotate them a little different.
John
Old 08-02-2006, 03:24 PM
Traitor's Avatar
John
I could'nt rotate my pass side clamp much, it looks like his, the bolt is rotated a little futher to the right, but the bolt side is still down a bit. I could not position it to the side. I've already carved a couple speedbumps with it.
Band clamps are going on this weekend (should have done it to begin with)
Old 08-02-2006, 03:34 PM
02NBMSLPSS's Avatar
Yeah you probably have a leak, my car sounds good up to about 2500, after that it sounds like a chevy pickup with cherry bombs. I do have a faint tick at idle but does not increase at wot.
Old 08-02-2006, 03:56 PM
Traitor's Avatar
lol.
Mine is the exact opposite. Maybe we both like different sounds. Mine sounds raw, burbly, raspy down low and toned, clean up top. It's weird.
I'm pretty sure I have a leak like you said, I won't have time to jack it up till this weekend.
I hope it's a leak, this may be how it is supposed to sound. I kind of hope not.
Old 08-02-2006, 04:10 PM
02NBMSLPSS's Avatar
lol.
I have seen a thread on here where our dd cat back has a restrictor plate in the dr side tail pipe not all but some to reduce noise even more. I dont know how to check unless I chopped up the tail pipes. This may have something to do with it.
I have heard everybody saying to go with a catted y which will help out alot.
Old 08-02-2006, 04:46 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
get some good BAND CLAMPS..those u-bolt clamps are old-school and nowhere near as good for certain things such as header/y connections...get stainless.
Old 08-02-2006, 06:02 PM
02NBMSLPSS's Avatar
Originally Posted by NHRAMAN
get some good BAND CLAMPS..those u-bolt clamps and old-school and nowhere near as good for certain things such as header/y connections...get stainless.
My car has no leaks whatsoever, I just think the car sounds like *** without a catted y. Should have got that instead of the ory, and the exhaust fumes when the t tops are off is rough. I didnt really care about stainless either because the car will never see snow and usually sits in the garage. I know if I get caught in a rainstorm once in awhile might cause a little rust but nothing phenomenal.
Old 08-02-2006, 09:38 PM
Rescue Ranger's Avatar
my TSP catted y blows. Not sure how to get the thing to line up better and not rattle the **** out of my floor
