Help!! Bad MPG
Old 08-02-2006, 06:46 PM
Cory1970's Avatar
Default Help!! Bad MPG
I have 98 z28 m6 with 120k on the clock. The car had been getting 28 mpg on the hwy, went down to 24. So I changed plugs(tr55) and wires(msd), but my mileage stayed the same. The mileage has now gone down to 21mpg on the hwy. What should I check next!! This is the first ls1 I have owned. I have changed to ported GMMG exhaust manifolds, but that did not change my mileage
Old 08-02-2006, 06:58 PM
jam01's Avatar
have the oxygen sensors checked. they could be going bad.
Old 08-02-2006, 07:06 PM
staringback05's Avatar
change your filter, and has anything messed with your maf?
Old 08-02-2006, 07:08 PM
Cory1970's Avatar
I do have a de-screened mas air. My air filter is good. I show no check engine codes.
Old 08-02-2006, 07:13 PM
Cory1970's Avatar
before it was getting bad mileage I could beat a stock bmw e46 M3, now I can just keep up with stock 06 mustang gts.
Old 08-02-2006, 07:20 PM
Tech Resident
ChocoTaco369's Avatar
ouch. bad idea right there.
i'd guess oxygen sensors. after that, bad catalytic converter. after that, bad spark plugs.
honestly, the more i think about it, the more i think bad catalytic converter. that'll kill your mpg and power due to increased back pressure, especially at cruise. go behind your car and smell your exhaust. see if there's a hint of rotten eggs - a sulfur smell. that means your cat or cats are shot.
Old 08-02-2006, 07:27 PM
Firebirdfan's Avatar
+1 for bad cats
Check them out. A guy I work with had a 3rd gen TA that wouldn't even start because the cats were so crapped up. Check them out along with the O2 sensors.
Old 08-02-2006, 07:28 PM
lol just dont stay back there to long....CHECK YOUR FUEL FILTER....take it off blow it out and ull see what i mean
Cory1970's Avatar
I have looked at the cats, they do not look cloged.
the plugs are new
Old 08-02-2006, 07:30 PM
Cory1970's Avatar
i have also changed the fuel filter
Old 08-02-2006, 07:33 PM
Cory1970's Avatar
more ideas!
Old 08-02-2006, 07:49 PM
Uhh...Stop driving 120mph....
Seriously, I don't know. The next test is the O2 sensors
Old 08-02-2006, 10:58 PM
taintedmeat's Avatar
Get someone with hptuners or efi live to see how fast your o2's are switching, one of them is probably slow. They can be slow and still not throw any codes. I'm pretty sure I have a lazy one myself...and I'm too lazy to replace it.
Old 08-02-2006, 11:43 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Stroker time. It only gets worse from here.
Old 08-02-2006, 11:51 PM
Ubergeist's Avatar
I am having a similiar problem, I went down to 21city to 15city.
Only really difference is the A/C has been on. Does it make that big of a difference. I can't imagine so.been 100 plus degrees here lately.
May not be bad for some but for a penguin like me it sucks.
Old 08-02-2006, 11:58 PM
nokeman's Avatar
All I know is mine has gone down as well since this heat has been so bad. My AC is on all the time cause its 100 degrees outside. I would imagine it does make some kind of difference
Old 08-03-2006, 11:29 AM
Tech Resident
the plugs are new
umm...how can you tell if the cats are clogged by looking at them? unless you saw the inside of them, which would involve cutting them off and rewelding them...
even so, the core could be compressed in the center but still look okay by peaking in it.
Old 08-03-2006, 11:48 AM
BlackBADaSS02's Avatar
No wonder why my gas milage has been so bad. I know my cats are bad. Now I guess I know why I can oly get 19 mpg.
Old 08-06-2006, 11:52 PM
Cory1970's Avatar
Now that you say it, I did just peak in there with a flash light when they were off the car. You could be right, they might be cloged in the center..... I will do the smell test.
Old 08-06-2006, 11:56 PM
Cory1970's Avatar
Okay, I just put new O2's in and I cleaned my mass air. I will test my gas mileage this week and report back.... stay tuned...
