Sponsored by: DashLynx
What's the strongest rattle can clear coat?
Old 08-05-2006, 04:05 PM
SVT THIS's Avatar
Default What's the strongest rattle can clear coat?
I am in the process of painting up my interior with some gloss black high performance enamel. I don't want to risk it scratching up from normal driving, usage, etc and would like to put on several coats of a strong, glossy clear coat. Who makes the strongest, glossiest clear coat??
Parbreak if ya read this your opinions appreciated
Old 08-05-2006, 04:24 PM
1SicV8's Avatar
i went to a local autopaint shop, they gave me some good stuff in a can, dont know the name. so id try that route
i have used duplicolor clear, it was alright but not as good as the other
Old 08-05-2006, 07:52 PM
parbreak's Avatar
Best bet is 2 part professional clearcoat. Probably can get some put in a can from a local bodyshop or autobody supply.
Old 08-05-2006, 11:17 PM
SVT THIS's Avatar
Thanks for the tips guys
Old 08-06-2006, 12:02 AM
Sawzall and Welder Mod
Whistler's Avatar
Don't put 2 part automotive urethane over spray paint though, it will cause the spray paint to wrinkle and lift.
Old 08-06-2006, 12:07 AM
stryker14's Avatar
I was talking with my local paint rep about painting a boat and ended up talking to the rep for house of kolor/valspar who was telling me about a clear that is a 2 part system like all automotive clears but once dry it can not be buffed out. He said that it will harden up so much that it is extremely difficult to put any kind of scratch in it. Hence why you cant wetsand and buff it out. I didnt get all the details but I know if I decide to paint interior pieces I will get some more info on this product.
Old 08-06-2006, 12:14 AM
Whistler's Avatar
Regular 2 part urethane clear is pretty durable in interior use, it's the spray paint with no hardener that looks like **** with normal use.
Old 08-06-2006, 07:32 AM
thesoundandthefury's Avatar
Have you seen this?:
http://www.innate.com/Paint/nanocoating.htm
Old 08-06-2006, 12:12 PM
stryker14's Avatar
yeah I remember seeing that a while back. looks like a good product that is somewhat scratch resistant but still allows you to wetsand and buff out. I am curious if the clear that I mentioned allows or comes with a flex agent. The main thing I am interested in is the toughness of the product that will keep scratches down. If it really cant be wetsanded like the rep said then it sounds like it will do what im looking for. Only downside would be applying the clear and making sure that it lays down smooth otherwise your SOL
Old 08-06-2006, 03:02 PM
SVT THIS's Avatar
Well I have my entire center console out and am in the process of priming it with Duplicolor high build primer. I am thinking about biting the bullet on this piece and seeing if a body shop will let me buy some high gloss black and clear in spray cans. I have a paint gun as well-should I just try and buy a very small amount?
So far, the only problems I have had with the high performance enamel is the appearance of scratches through the paint. I primed the original plastic pieces with about a can of high build primer then sanded it down with 150, 220, 400 and 800 grit. I had the primer sanded to almost a gloss finish. I sprayed on several coats of the enamel and after a day or 2 of drying it looked great. High quality, deep black, glossy automotive finish. However, I could see teeny tiny scratches all over the piece. You cannot wetsand enamel-if you haven't tried it it pretty much turns the black into a dull grey. Anyways, they were just the back speaker panels in the rear hatch so several little scratches are fine. However, I want the ones seen normally to be perfect.
So, here are my questions:
Were the scratches I saw with the rear panels a result from not sanding the primer further down with 1000 grit and up? Or is it a result of not being able to wetsand the final painted product?
If it is just a result of not sanding down further, would you reccommend I use the enamel paint I already have, or drop the $50 or so on black paint, plus whatever the hardener is, and probably another $50 on clear with additional hardener for that?
Thanks for the tips
Old 08-06-2006, 03:33 PM
Whistler's Avatar
If it's just black you're after, you can get some black urethane enamel from the body shop supply store and shoot that on with your spray gun. It mixes at a 8:2:1 ratio with reducer and hardener. Since it has hardener it will be more resistant to scratching than the spray paint will, and won't need a clear.
Old 08-07-2006, 12:08 AM
SVT THIS's Avatar
Cool I'll give them a call tomorrow. Thanks.
BTW Whistler, how'd your customer like that TRex???
Old 08-07-2006, 08:39 PM
SVT THIS's Avatar
Well I said screw it and broke down and got Dupont automotive grade high gloss black-I can't remember the exact paint code. It was about $40 for a quart of the paint and hardener. I'll be redoing my rear speaker panels, back seat speaker panels, a-pillars, floor sill pieces and center console. Hopefully a quart will do, if not, I guess I'm out another $40.
I am also going to go back and get GM Sebring Silver for my dash trim pieces, center console top, and several other pieces. Does anyone happen to know the Dupont paint code for 1998 GM Sebring Silver?
When finished with the pieces, wetsanding will most likely be necessary. What grit should I use? I already have 1000, 1500 and 2000 grit. Should I start lower or will 1000 be a good starting point? How much time should I spend on each piece when wetsanding? Since the paint has a hardener, a clearcoat will NOT be necessary, correct? Should I still invest the extra cash and get one, or will I just be wasting my money? Thanks
Quick Reply: What's the strongest rattle can clear coat?
