Will my new cam work for turbo???
Old 08-05-2006, 11:34 PM
ninetres's Avatar
Default Will my new cam work for turbo???
I bought a brand new cam for an N/A heads and cam package and now have decided to go turbo.
My buddy got good numbers out of a reverse split so I am wondering if mine will work. It is:
228/232 588-595 114+2 LSA
Please help, thanks.
Old 08-06-2006, 02:41 AM
gametech's Avatar
Best - maybe not. Will it work? - yes, and probably quite well.
Old 08-06-2006, 05:06 AM
Mr_president's Avatar
hmmm i like it!!
Old 08-06-2006, 09:00 AM
engineermike's Avatar
It will be fine. I have a 224/236-114 cam in my turbo LT1 and it runs pretty well. I've pulled 143 mph in the quarter with no weight reduction in 95 deg heat. The exhaust lobe isn't as critical as most people think.
Old 08-06-2006, 11:01 AM
ninetres's Avatar
Thanks so far. Would I be able to buy a cam that aids spooling time compared to this one...or make better power? I am not sure how cam specs afftect turbos.
The cam I have is a brand new AFR custom grind so I could imagine I could sell it pretty easy.
Old 08-13-2006, 09:59 PM
ninetres's Avatar
UPDATE:
I am still concerned (as is my mechanic) that we are leaving HP on the table using this cam. He thinks the High duration and midrange LSA will provide too much overlap and blow through.
Should I suck it up and order a custom grind? I was thinking a reverse split with lower duration (high 2teens, low 220s) and a 115 or higher lsa. It sure would be nice to have a turbo car with a lumpy cam though
Old 08-13-2006, 10:11 PM
black_z's Avatar
I think its a little too heavy on the exhaust duration. How high are you spinning hte motor?
Old 08-13-2006, 10:18 PM
ninetres's Avatar
Depends were my cam (which ever I go with) stops making power, lol. I will be using out of the box Patriot stg 3 LQ9 heads though. I would like to keep it under 6600 rpms.
Old 08-13-2006, 10:32 PM
cjg454ss's Avatar
wiould this cam be any good?
comp cam 236/242 .598/.610 114+4
Old 08-13-2006, 10:39 PM
ninetres's Avatar
Hella jacking my thread
Old 08-13-2006, 11:33 PM
trtturbo's Avatar
we have used a 224/230 112 cam and had damn good results. I say go for it.
Old 08-14-2006, 09:57 AM
ninetres's Avatar
That sounds a little more promising. What do you mean "good results"?
Old 08-14-2006, 10:17 AM
bowtieman81's Avatar
What is your setup? Seems the general consensus is to run a little more intake duration than exhaust, depending on setup.
Old 08-14-2006, 10:28 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Power goal?
Big cams like that might be all top end power, and the midrange and torque might not be as strong as with a smaller cam.
Old 08-14-2006, 10:53 AM
NassyVette's Avatar
Ditto. I remember seeing somewhere that truck manifolds like 6 degrees between intake/exhaust in a reverse split with a tight LSA (ie. 226/220 115/116). Better flowing headers like less of split or standard split (226/224 or 224/224 etc).
Old 08-14-2006, 11:48 AM
Yep, that is what I have gathered in talking with members and sponsors about turbo cams. That type of cam should give good low-mid range power while still turning out a good top end. Exactly what I would want in a street car.
Old 08-14-2006, 06:28 PM
agreeeeeeeeeeed~! stick with that cam and try it i think it will be differnt see what it does! you can always turn the boost up
Old 08-14-2006, 06:38 PM
67Firebird455's Avatar
I think it'll run great. If you had a cam with a RIDICULOUS amount of valve overlap then I would have to vote against it. The fact that there isn't a giant split, and you still have a reasonable LSA, I would say run it...
Old 08-14-2006, 06:42 PM
Got Me SOM's Avatar
this is good news I run a 224/230 .581/.588 on a 115, I am possibly considering going turbo next year. I dont know.
Old 08-14-2006, 06:46 PM
cablebandit's Avatar
your current cam might make it easier to run big numbers on pump gas as some of the "blow thru" will be in the midrange where cylinder pressure is high (around full spool up and peak tq). If pump gas is not a concern then maybe something is better.
