tranny cooler fan - on all the time
going to be installing my transcooller soon, i have a fan for it but dont have a thermostat to turn it on as im cheap.
is it ok to run the fan all the time cooling the transfluid more when it might not need it?
any problems with the trans temp getting to cool?
Moderator
If it's a little muffin fan then a thermostat from Digi-Key
like P/N 317-1019-ND would set you back a whole $8.12;
if it's more than an amp draw you'd need a relay too.
If fluid is -too- cool then you might not see lockup.
Originally Posted by jmm98LS1
I believe minimum lock up temp is pretty low though, around 80F isn't it? If you're little fan keeps your fluid from reaching lockup temp, post the part number please!
