catch can needed please help
Old 08-12-2006, 03:54 PM
MiaSSmaro98's Avatar
Default catch can needed please help
hey guys im still buying alot of parts for my build,but im now in the catch can part of the build im going by this route a member posted for the pcv system for boost.basically were can i get a can with 2 in ports and 1 out port?because they posted it will be bad to run the lines into a 2into1 fitting and then to the can.
Old 08-12-2006, 04:07 PM
Boostaholic's Avatar
That 2 into 1 for your catch can is wrong unless you get a check valve there also it will blow boost out.
I just run Valvecover ---> CatchCan ---> VacPump / Turbo
Old 08-12-2006, 04:58 PM
so wats posted above is wrong?i already have a GN check vavle which i bought from kirban motorsports.my passenger side cover has 2 ports and i stil have to buy the ls6 vavlley cover.so what should i do for a trouble free setup?
Old 08-12-2006, 05:18 PM
The line that goes from your intake to valvecover to catch can is wrong
Old 08-12-2006, 05:57 PM
no ur getting confuse a line from one port on the cover and a line from the ls6 valley cover go to a catch can and then to the airfilter on the turbo,then the rear port on the cover gos to a port behind the throttle body which has a check vavle in the middle.i know the drawing is bad
Old 08-12-2006, 06:01 PM
here is a example
Old 08-12-2006, 06:23 PM
okay but i dont have a pump
Old 08-12-2006, 06:37 PM
ok just take that out of the picture then, hook lines up as if it was not there
Old 08-12-2006, 06:39 PM
Senior Member
Country Boy's Avatar
That drawing isnt wrong. Its mine. There was 2 of them that I made. The one posted has a line from the valvecover tee'ing to the LS6 cover to the can and then to the inlet side of the turbo. Then one from the other valvecover boss to the intake port with a check valve to pull a vacuum at idle and the check valve closes as positive pressure is introduced.
Old 08-12-2006, 06:41 PM
Senior Member
here is a example
That is the same drawing as mine, but I tee'ed my LS6 cover into the the one that goes to the can to pull more vacuum under boost.
Oh your right, I made a mistake and thought that was the intake not a LS6 valley cover.
Good call
Senior Member
Its all good. I have some serious paint skillz
Old 08-12-2006, 06:43 PM
89Formulaws6's Avatar
search for a post i made on catch cans a few months back, i made a simple drawing alot of people actually saved haha
Old 08-12-2006, 07:07 PM
Senior Member
your pic is worse than mine..
Old 08-12-2006, 07:32 PM
MECHAM's Avatar
yall are so newbs at drawings...
i changed mine around some
passenger rear plug == small filter
driver rear plug == small filter
driver front plug -> catch can -> turbo inlet
ls6 valley -> check valve -> intake manifold
Old 08-12-2006, 07:44 PM
Senior Member
What happened to this link, pro? LOL
http://image58.webshots.com/58/8/35/...1AHBoTw_ph.jpg
Old 08-12-2006, 11:13 PM
i stated it was an ls6 cover and i did saved it from ur post countboy
Old 08-12-2006, 11:16 PM
Yep I re-read your post and realized that, sorry for the misinformation.
Old 08-13-2006, 12:37 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
any places where to get a nice catch can besides ebay?
Old 08-13-2006, 01:28 PM
usually alot of the import websites have good ones like greddy hks exc.otherwise ebay or an oil/water seperator from home depot
