double clutching?
Old 08-14-2006, 10:34 AM
2KnbmTA's Avatar
Default double clutching?
ive tried it, and it does feel like it shifts better, but is it worth the extra stress on the clutch?
Old 08-15-2006, 11:25 AM
Lemonhead's Avatar
well if you dont double clutch your gonna feel the car buck because its gonna be coming in from a lower rpm to a higher without being revved up. you will wear out your tranny without double clutching a lot faster
Old 08-15-2006, 12:10 PM
BJM
BJM's Avatar
Double clutching does less wear and tear on everything. You are not forcing the syncros to do anything at all if you double clutch perfectly.
Old 08-15-2006, 12:24 PM
chadtx01's Avatar
Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake!
Old 08-15-2006, 01:15 PM
nyteryder167's Avatar
Beat me to the punch!!
Old 08-15-2006, 01:27 PM
RaNsOm's Avatar
I picked up .3 tenths by double clutching.
Old 08-15-2006, 01:33 PM
z98
z98's Avatar
Double clutching has no use when racing.
Old 08-15-2006, 01:49 PM
NoMoreLS1's Avatar
Talking
"Ask any racer. Any real racer. It doesn't matter if you win by an inch or a mile. Winning's winning."
Old 08-15-2006, 01:51 PM
MrDude_1's Avatar
double clutch? fuuuck.. when im racing, i bearly single clutch.
Old 08-15-2006, 02:46 PM
Cap'n Pete's Avatar
tell me you're kidding??
(or do you mean you ran 3 tenths slower??? )
Old 08-15-2006, 04:45 PM
2KnbmTA's Avatar
yeah i dont know how you can race and double clutch. i dont know about you guys, but i cant shift nearly as fast, with the reason being obvious
Old 08-15-2006, 09:21 PM
MyWs62FaST4u's Avatar
Lol..how Does One "double Clutch"
(hee Hee)
Old 08-15-2006, 10:12 PM
Zentenk's Avatar
(hee Hee)
You install 2 clutches.
Old 08-15-2006, 10:16 PM
SSilverSSurfer's Avatar
i can double clutch in my auto and picked up a whole second
Old 08-15-2006, 11:52 PM
barracuda_440's Avatar
what exactly is double clutching? dont semi drivers do it?
Old 08-16-2006, 08:04 AM
Cap'n Pete's Avatar
Clutch, shift into neutral, off the clutch, clutch, shift into gear, off the clutch.
5th gear is messed/messing up in my tranny, and it actually DOES make it easier to go by double-clutching. In terms of racing though, it could only help slow you down IMO.
Old 08-16-2006, 11:28 AM
kenkaru's Avatar
If you're not double clutching, you might was well granny shift. Just watch out that you don't blow the welds on the intake. I hate it when that happens.
FYI, almost every post in this thread is sarcastic. Including this one.
Cap'n Pete has it right.
I finally bought 2F-2F last night. My wife and I watch them as slapstick comedies. Brian is such a
Old 08-16-2006, 12:17 PM
RaNsOm's Avatar
I said .3 tenths. Thats .03
but yes I was being sarcastic, lol.
Old 08-16-2006, 01:05 PM
Jimmard's Avatar
Well, since every response in this thread has been sarcastic, just about, I'll answer it for ya. There is no need for double clutching on new transmissions for that is what syncros are for. Back in the old days with transmissions without syncros, I believe double clutching did make a difference. Correct me if I'm wrong tho.
Old 08-16-2006, 02:21 PM
BJM
BJM's Avatar
You are essentially correct. But when I downshift from 6 to 3 or more often from 6 to 4, I always double clutch (clutch 1 into neutral, let out, rev everything up, clutch 2, shift into 3 (or 4), let out again). When I do it right I get no jerking, I am simply accelerating like crazy and my syncros get to live another day. Doing it the other way I make the syncros do their job (that is what they are there for), then I have to rev match as I let out again to avoid jerking. I was never as good at it that way so I got good at double clutching instead.
Double clutching an upshift makes no sense.
Quick Reply: double clutching?
