Installing Hooker Headers, what all will i need
Old 08-15-2006, 12:47 AM
The PAT WS6's Avatar
Default Installing Hooker Headers, what all will i need
Just got some Hooker Headers just wondering what else will i need? can i reuse my gaskets if not which ones to get? and will i need to get o2 extensions? also i will be installing an ory so should i get the rears tuned out or should i get simulators?
TIA
Old 08-15-2006, 01:31 AM
firehawk0623's Avatar
thay come with all you need
Old 08-15-2006, 01:48 AM
zach_ws6's Avatar
i re-used my factory gaskets and have NO leaks. they are way better than the pacesetter paper ones.(not sure about the hooker gaskets). as far as the O2 sensors go, there are different routes you could take. you need to have the front ones hooked up for sure. some people splice, i just went to autozone and got some corvette O2's. the wires are way longer than the f-body ones. i just left my rears unplugged and i am getting a tune. i would reccomend a tune anyway. goodluck. (hope you have small hands, j/k, you'll be alright)
Old 08-15-2006, 12:13 PM
yeah i was aksing cus i bought used ones so i wont need new gaskets? and yes i plan on gettin rid of my AIR and Undoing my rear o2's so when i go to get all of it deleted out i wont have a problem. As for the Front o2's i might go with the 13111's on for the vette.
Old 08-15-2006, 12:14 PM
oh and btw i do got small hands so im sure it will make it alot easier. and also i have my tranny out now so im not sure if that will make it any easier or not
Old 08-15-2006, 12:17 PM
farnoush's Avatar
If you want to use the extensions let me know, Ive got 4 brand new 12" extensions Ill sell you.
Old 08-15-2006, 11:56 PM
ok my gaskets when i toook the out the came seperated into 3 indvidual ones so should i get new onees and if so where and what? and as far as bolts should i use the same ones?
Old 08-16-2006, 12:09 AM
Fire-formula 93's Avatar
Most people make a trip to the dealer and buy the GM ones. I believe they are around $30. Stock bolts are fine to use, just torque them down every once in a while, they can come loose on you.
