What is your launch rpm with stall?
Old 08-15-2006, 07:24 PM
lunatik's Avatar
Default What is your launch rpm with stall?
As the title implies, I was wondering what rpm you stalled guys bring it to just before you launch? Even with DR's can you acheive near full stall rpm? I know without a transbreak its very difficult/impossible. This question is directed to the footbreak guys. Example: with a 3800 stall do you launch at say 2500-3000?
Old 08-15-2006, 07:33 PM
gillbot's Avatar
off idle, no transbrake.
With DR's I can't get anywhere near full RPM at the line before I start pushing the car forward.
Old 08-15-2006, 07:39 PM
lunatik's Avatar
Just for kicks and giggles what stall are you running? High str?
Old 08-15-2006, 07:44 PM
Roarin_8's Avatar
Footbraked to 3500 rpms, that was before the cam though. I'll try again when I go in September.
I did get as high as 4000 but the trans didn't like that too much.
Old 08-15-2006, 07:56 PM
lunatik's Avatar
How did it act up?
Old 08-15-2006, 08:58 PM
nikon1999's Avatar
i have an ss3600 and cant get mine to foot brake past 1400 rpm the dr's just wont hold it. Need some bigger/better tires have a 3.73 gear in the rear
Old 08-15-2006, 09:05 PM
Fabian's Avatar
****, so my Vig 3600 is gonna be useless? I have nittos out back and 2.73s gears....I havent ran it yet because I wont be done til Saturday at the earliest.
Old 08-15-2006, 09:14 PM
nikon1999's Avatar
how is it going to be useless? even though i cant stall my car up great i still cut 1.7x 60's... you having a 2.73 gear should help with traction to, you should be happy with the improvement, converter helps with shift extention and everything to
Old 08-15-2006, 09:18 PM
irnbru83's Avatar
is it still not more beneficial to upgrade to 3.73?
Old 08-15-2006, 11:31 PM
lunatik's Avatar
your flash stall must be great too and the str cant be too shabby.
Old 08-15-2006, 11:54 PM
sixvi6-camaro's Avatar
no way it will be useless! wait until you punch it from a standstill for the first time with the stall.. it will be insta-burnout with those nittos. don't worry about having a 2.73... Stalls do way more than gears especially if you have a 2.73.
I stall mine up to 2200 or so and let her rip from there. no problems with traction on MT radials but my car is pretty much stock with the mods in the sig on a speed inc Basic tune. I managed consistant 12.70-12.75's with 1.7x 60's.
Old 08-16-2006, 12:24 AM
Roarin_8's Avatar
Originally Posted by lunatik
How did it act up?
It shifted into second at 4500 rpms and then locked me out of 3rd and 1st(limp mode)
Old 08-16-2006, 03:51 AM
gillbot's Avatar
Yank PT4000, 2.2str.
Old 08-16-2006, 05:07 AM
Old Drag Racer
Smokinstorm's Avatar
PT4000 converter here. Stalling the converter up to 2800-3000 has netted us the best results with the MT Drag Radials. Any more and the tires break loose. Slicks might like a little more launch RPM but I don't have a set of those at the moment to try. My SI car has been running 7.50's to 7.60's all Summer in the 1/8th @ 89-90 MPH (7.50 best, 7.63 worst on a 90+ degree day) with 60's ranging from 1.59 to 1.63. I've got 3.90 gears in the rear now. I know that factors into what launch RPM works best so I just wanted to mention the gear as well.
Old 08-16-2006, 05:09 AM
BlackHawk T/A's Avatar
550rpm.
Old 08-16-2006, 06:45 AM
Fabian's Avatar
Ah, I just meant that I wont be able to go anywhere near what the stall speed is. I was thinking of getting a transbrake too
I also installed a shiftkit and a tranny cooler.
Old 08-16-2006, 07:40 AM
lunatik's Avatar
Originally Posted by BlackHawk T/A
550rpm.
, cool, another vote for idle.
Old 08-16-2006, 07:56 AM
lunatik's Avatar
thanks everybody, this is the feedback i was fishing for.
Old 08-16-2006, 04:39 PM
Yeah, it still hits the tires damn hard because it flashes. You need to stick fairly well to tame it.
Old 08-16-2006, 09:37 PM
Pontiacerator
RevGTO's Avatar
550rpm.
So far my best results have also been from stomping it at idle. But after it cools off, I'm going back to the track and am going to give stalling it up another go and see how it does.
Quick Reply: What is your launch rpm with stall?
