Kroger carries E85 now! will it work in a regular car?
Old 08-21-2006, 12:09 PM
InsomZ's Avatar
Default Kroger carries E85 now! will it work in a regular car?
I noticed at lunch today the Kroger in Los Colinas has e85 @ the pumps already! i thought it would be a while before they got it to market.
how do i figure out if it will run in the saturn or jeep? i guess i might experiment with the jeep since its on its last breathe anyways.
Old 08-21-2006, 12:10 PM
01ArcticSS's Avatar
Don't do it!!
You have to have a "Flex fuel" vehicle to run that stuff.
Old 08-21-2006, 12:11 PM
hawgs's Avatar
Do it!!
Old 08-21-2006, 12:12 PM
Brandon Boomhauer's Avatar
ahhhh he posts!
and you have to have a flex fuel capable vehicle to run the stuff.
I need to do some reading on it, but last I heard, fuel milage suffered near 25%. Though I think the ethanol in the fuel now is hurting milage too, just not as bad.
once again, i need to do some research, so correct me if im wrong.
Old 08-21-2006, 12:41 PM
mcowart's Avatar
correct..flex fuel cars run it..they have bigge injectors and a diff fuel pump i believe...some o will chime in its been a while since i read about them..
Old 08-21-2006, 01:10 PM
SPEEDYws6's Avatar
Try it, but don't say we didn't warn you. It takes almost twice the fuel to run e85. Your fuel system isn't up to that, and your PCM won't know how to adjust for it.
Old 08-21-2006, 01:11 PM
InsomZ's Avatar
darn.. oh well sounds like a good way to off the jeep then.
Old 08-21-2006, 01:12 PM
Josh McGrath's Avatar
how much was it?
Old 08-21-2006, 01:14 PM
InsomZ's Avatar
$2.45/gallon
http://e85vehicles.com/e85-texas.htm
guess thats one of the 3 places kroger is testing it out in tx. I read something about it being higher performance.. equivilant of 105 octane.
lower gas mileage by 20% or so.
Old 08-21-2006, 01:46 PM
LS7 Member
UTzo6's Avatar
it will only work if you run it in junction with a 250 shot
Old 08-21-2006, 02:04 PM
BP
BP's Avatar
It's closer to 120 octane and fuel economy is more like 60% of the 10% crap we have to run now. If your car isn't FFV it probably won't even start with E85 in it and if it does you won't make it but a couple of blocks before you burn holes in the pistons.
Old 08-21-2006, 02:39 PM
Toxic Texan's Avatar
http://www.e85fuel.com/e85101/flexfuelvehicles.php
See if yours is on the list.
Old 08-21-2006, 03:05 PM
BigSteele's Avatar
haha
are you in your place yet? you need to check out our house, its 250% better than the taj
Old 08-21-2006, 03:10 PM
red90cobra's Avatar
i think i'm gonna try it once it get closer to me. I'm gonna try it in the race car.
Old 08-21-2006, 03:16 PM
Ravenous T\A's Avatar
I thought you also had to have different seals in your lines cause the reg seals that gas engines use would get eatin by the E85 stuff?
Old 08-21-2006, 03:28 PM
jmurray87's Avatar
I heard on the news some people have put e85 in there cars not knowing they shouldnt. Better keep watchin where we fill and make sure its not e85!
Old 08-21-2006, 03:36 PM
InsomZ's Avatar
i bet it will be a week before their is a lawsuit over a soccer mom blowing an engine cause their isn't a warning label.
Old 08-21-2006, 03:39 PM
LS7 Member
UTzo6's Avatar
Originally Posted by BigSteele
haha
In the new place and i'll def need to come checkout yours. Esp if you have that kegerator
Old 08-21-2006, 05:10 PM
Mustang Moderator
Stang Man's Avatar
I have witnessed a legitimate 10% decrease in fuel economy when I run the 10% ethanol ****. 18mpg down from 20 mpg.
I like stopping in the small towns for gas, some of them still don't run the ethanol gas!
Arron
Old 08-21-2006, 05:33 PM
kickassT/A's Avatar
we've had 3 new tahoes come in for this in the last 2 weeks. just because you have a new vehicle doesn't mean it can run it. has to be a flex fuel
