OK, I've done some searches, but please post pics of fuel rail installs
Like I said, I've done some searches and have found some great examples of installs, but I'd like to see some more.
This will be on a GTO, so the plumbing will be a tad different, but, close enough to be the same.
Thanks for your help guys.
The first one is the setup before I put it in, notice the rails are only joined at the back.
In the second picture the rails are still joined at the back but also have a linking pipe at the front too now.
None of a GTO, but some F-Body picts (you may have to go through some of the albums to find the fuel rails):
http://www.harrisspeedworks.com/gall...dex.php?cat=17
Matt
Matt
With the GTO, the factory hard line is at the fire wall and with the fittings that Speed Inc supply, I can't really see how they plan on you plumbing it.
I'll get some good pics of the install so you guys can see what I'm talking about.
daveread00ss - You found a photo of my rail setup on photobucket, it seems to be becoming famous, was on another thread too.
Joining to the factory lines could have been a pain in the *** for me, as there are no local shopsw with quick disconnect tools and certainly no connectors to fit on them. I chose a braided hose with an internal diameter of 11mm (about half inch) Slid this over the factory hard line and then used a couple of cable clamps to hold it. Was an extremly tight fit.
The parts that are supplied for the GTO kit are the parts that are supplied for the F Bod kit and it just isn't quite the same. Hopefully I'll get that stuff done next week and post pics.
