were do i order tires for skinneys
Old 08-24-2006, 03:34 PM
deadlyz28's Avatar
Default were do i order tires for skinneys
trying to find were i can order 165/15 tires or whatever else is a good size...for 15X3.5 skinneys, any help would be great.
Old 08-24-2006, 03:37 PM
badcompanyvpws6's Avatar
ask badcompanyvpws6 over on ls2 cause he has some but i don't know where he got his from.
Old 08-24-2006, 03:41 PM
Pavlock Performance's Avatar
from what i hear they stopped making 165/15's but they are still around. i got lucky and found some new. check local shops or check out procise tire in spring off 249. 281.255.3950 ask for mike. they are a bunch of dumb rednecks but stay on their asses and they will hook you up. i just called for you and he;s checkin btw.
Old 08-24-2006, 03:49 PM
deadlyz28's Avatar
i called a place up here in plano and they have some but there good for 35psi, is that ok?
Old 08-24-2006, 03:51 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Signet makes them.
Old 08-24-2006, 03:55 PM
i run kumhos on my nova and formula because they are allot stiffer sidewalls than most i have seen and can support a heavier car.
Old 08-24-2006, 03:57 PM
9 Sec. Club!!!
dan03mach's Avatar
Firestone still has 165R 15's.. They were like 30 buck each or you can buy some ET Fronts..
Old 08-24-2006, 06:45 PM
cabesas's Avatar
i had a hard time finding them to but i got some from firestone they were like 90 bucks for both of them
Old 08-24-2006, 07:41 PM
95greenmaro's Avatar
discount tire, if you are in houston i am off of sheldon rd
Old 08-24-2006, 08:31 PM
V6 Bird's Avatar
Dayton Widetracks hold 44 psi max. Signets are JUNK. 36psi for them and roll over real easy.
Old 08-24-2006, 08:36 PM
deadlyz28's Avatar
hey mike were can i order these dayton ones???
Old 08-25-2006, 08:28 AM
V6 Bird's Avatar
From the phonebook of a tire place who sells Dayton tires....Its really easy if you will put the joint down
Old 08-25-2006, 09:29 AM
Scooter@MTI's Avatar
Spend the extra cash and buy a set of the 8 ply Mickey Thompson (MTT-1573) they are worth the money. Your car will drive so much nicer with the MT's. Had the signets and they are crap.
