What Mods Should I Get
Old 08-27-2006, 11:54 AM
mycamaroSS's Avatar
Talking What Mods Should I Get
Everyone, i need a list of mods that i should get, good mods. I'm gonna be gettind 4:10 gears, B&M Shifter, Hooker longtube headers, and i need some more ideas. Thanks. O and i know i houldnt be posting this up in this forum but which tires should i get and is 275 a good size or should i get bigger
Old 08-27-2006, 01:53 PM
presto_z's Avatar
first m6 mod should be !CAGS (skip shift eliminator check out installuniversity.com and do it yourself for 50 cents insted of spending 30 bucks) u should deff get a lid, they are faily cheap and help your car breath..dont forget the free ram air mod..your gonna want an ory and catback system (or true duals) and u may want to consider getting diffrent headers (from what i hear you can get better headers for cheaper... pacesetters seem to be very common and are the best bang for the buck).... consider getting a bigger tb (port your stocker out and save 350-400 bucks over an aftermarket)...... i have 295's and i wish i had wider.... being ur stick and ur gonna have 4:10's i would fit as much rubber under there as i could but only as wide as your wheels will saftly fit.....
Old 08-27-2006, 02:09 PM
blackbird00's Avatar
get ur *** a set of DR radials i have 4.10s and 315 nittos and i can breal them loose in a first gear roll. Ull love ur car alot better with DR
Old 08-27-2006, 02:59 PM
BayAreaSS's Avatar
All of the above.....if your car is 98-00 you should upgrade your intake manifold. (LS6,FAST)
Maybe you can consider a cam!
Old 08-27-2006, 03:18 PM
jpat1023's Avatar
Go to New Owners section and click the sticky named "so you wanna be fast". Lot's of info on mods.
Old 08-27-2006, 03:57 PM
mycamaroSS's Avatar
thanks guys and yea that's the first thing i went to look for was the skip shift eliminator. Alright, but i can never find tires bigger than 275, do you know a website to go to to check em' out
Old 08-27-2006, 04:01 PM
Beasst8's Avatar
tirerack.com
Old 08-28-2006, 09:03 AM
Adam_346's Avatar
Cat-back , Cut-outs , Air , Drag Radials , Short stick
