which plug and wires?
Old 08-27-2006, 02:53 PM
stevensLS1's Avatar
Default which plug and wires?
i was wondering what type of plugs and wires you guys use. ive used ac delco's and taylor 10.4mm before and also msd 8.5mm's and tr-55's i believe. just curious what everyone else likes/uses.
Old 08-27-2006, 04:06 PM
Beasst8's Avatar
Mine are in my sig. There are many diff combos. Just depends on who you talk to.
Old 08-27-2006, 04:19 PM
TORCHD 02 TA's Avatar
i would say that 85%of peeps on LS1 here are using NGK TR55s.. but as for wires go i will be using MSDs i need to install them
i need to install both NGK and MSD
Old 08-27-2006, 04:45 PM
Starz T/A 17's Avatar
I got NGK tr55's and was going to replace the wires but I tested the old ones with 117K miles on them and they were in better shape the the new autolite wires I got from advanced so im still runnin factory wires
Old 08-27-2006, 05:46 PM
SweeTbone's Avatar
TR55s and Red MSD wires here.
TR55s are the most common plug. Wires can vary. From stock, MSD, Taylor, Accel and so on. IF you think you must go from using the stock wires, I highly recommend MSD. If you search a little, you'll find some POLLS that people started asking to vote for which wires. Good luck.
Old 08-27-2006, 09:03 PM
HeapaShifter's Avatar
TR55's and stock wires have been working good for me. MSD would be my second choice for wires. Although, I'll probably buy another set of stock wires when mine give out....the red LS6 wires.
Old 08-27-2006, 10:33 PM
stevensLS1's Avatar
ive got the tr-55's and msd wires right now just curious to what everyone is running.
Old 08-27-2006, 10:44 PM
Trev_SS's Avatar
i will be odering the msd's here real soon
Old 08-28-2006, 03:00 AM
qwik_ss's Avatar
NGK TR6's with MSD 8.5 wires here
Old 08-28-2006, 09:13 AM
LS69TA's Avatar
No problems with the MSD's here.
