Sponsored by: DashLynx
This is for you Lt1 guys
Old 08-29-2006, 12:35 AM
luckyou03's Avatar
Default This is for you Lt1 guys
Sanded the plastic with 400 grit
Duplicolor spray can high-build primer x 2 coats
Sanded with 800 grit
Duplicolor spray can gloss black x 2 coats black
Duplicolor spray can clear x 2 coat
Very lightly wet sanded 800 grit (I sanded to far, and had to repaint it)
Sanded 1000 grit
Used 3m rubbing compound and rubbed with a soft towel
Rubbed the fine scratches out with my fingers and rubbing compound
Probably an hour worth of sanding, paint and buffing and 2 hour paint dry time.
This is achievable with rattle can paint and a polishing towel:
and from a while ago, all rattle can and rubbing compound and a towel:
I'm about to pick up a $500 beater car. I'm gonna try to paint the entire car with duplicolor rattle can paint.
Old 08-29-2006, 01:17 AM
thesoundandthefury's Avatar
That came out really nice. Just out of curiosity, when you did your inner fenderwells what did you use? Clearcoat? Basecoat/clearcoat? High gloss enamel?
You should do the wire mod next.
Old 08-29-2006, 01:32 AM
luckyou03's Avatar
thanks. Rattle can duplicolor high-build primer, 2x gloss black, 2x clear
Old 08-29-2006, 02:03 AM
Thanks. I had to ask because I wasn't sure whether you were talking about the fuse box and power steering reservoir in the description or had the fenderwells included in that.
Old 08-29-2006, 02:47 AM
Adam_346's Avatar
Nice , thats one way to renew your car.
Old 08-29-2006, 07:26 AM
Blackbirdws6's Avatar
looks great. you have skills like my dad with the rattle can. I swear he pulls off some crazy stuff with those things.
-Brian
Quick Reply: This is for you Lt1 guys
