Unusual clutch sticking to floor problem - does it always
Old 08-29-2006, 08:31 PM
98_1LE's Avatar
Default Unusual clutch sticking to floor problem - does it always
The trans was recently rebuilt and the slave replaced while it was apart. Ever since the clutch pedal tends to stay down after being held in for >20 seconds. It does not have to be driven hard to stick.
The engagement point of the clutch also settles towards the floor the longer I hold in the clutch, to the point it was difficult to take out of gear while still running.
I am assuming the master needs replaced, but wanted to check with the experts. This is on my basically stock '98 Z28.
Old 08-29-2006, 09:20 PM
Summit2345's Avatar
had same problem it was the master i replaced it now its good as new
Old 08-31-2006, 05:40 PM
whatsaholden's Avatar
+1 master
Old 09-02-2006, 05:51 PM
98_1LE's Avatar
Thanks. A new master has the engagement point right at the top!
Old 09-02-2006, 11:17 PM
The PAT WS6's Avatar
deff. ur hyrdaulics
Old 09-02-2006, 11:43 PM
yay the master never fails!
