Daily Driven Cam?
Old 08-30-2006, 03:14 PM
HossZ28's Avatar
Default Daily Driven Cam?
Dont mean to annoy you guys with a question that has probably been asked 1000s of times but search is down still.
This cam will be a daily driven cam, I do not want to lose any driveability being that it is my only car. I will have full bolt-ons, matched stall, and the cnc ported ls6 heads from tsp at the time of the intsall. Also I dont want to raise my rpms past 6300 or 6400 rpms. I have been hearing that stock 4l60e's dont like anything past 6000 rpms. I am just looking for more power under the curve without raising rpms much.
Will diablo sport work with heads and a mild cam or do i need hptuners
Old 08-30-2006, 06:20 PM
BeachZ's Avatar
Well, you can't go wrong with a 224 cam. I'm sure that's what 90% of the responses will say. Also, I don't know anything about the Diablo, but you definitely will want a tune with an A4.
Old 08-30-2006, 06:23 PM
ldickson's Avatar
You will love the 224 cam.See sig.
Old 08-30-2006, 07:20 PM
HossZ28's Avatar
What rpms are you running that cam to. like I said before, I dont want to raise the rpms too much with a stock a4. And how much power can I expect out of a 224 cam and the ported ls6 heads?
Old 08-30-2006, 07:37 PM
eamador11's Avatar
get the 224/228@114 cam from AFR. perfect DDcam
Old 08-30-2006, 10:55 PM
BeachZ's Avatar
What kind (specs?) of valve springs would you be running?
Old 08-31-2006, 07:35 PM
HossZ28's Avatar
I was going to be running the stock set up, whatever it comes with. If it is worth it I will spend a little more and get 918 springs and the competition valves. i am not sure what the stock set up can handle.
Old 08-31-2006, 08:08 PM
redz_02's Avatar
Itsn't that more of a nitrous/boost cam, Seems like it would be almost identical to a 224 if not boosting. Definately better for a power adder. I would definately change the valve springs, 918's are an easy swap (stock behive design) the stock springs cannot handle that lift, and you can use your stock retainers. I would also swap the push rods and check the rocker arms. If you want to run dual valve springs you will need to buy new spring seats.
Old 08-31-2006, 10:20 PM
BeachZ's Avatar
You are really asking for trouble if you run stock springs with that cam. The stock springs can barely hand the stock cam. Break a spring and drop a valve...$$$$. 918s are good springs. They're good up to a .650 lift. But like any springs with an aftermarket cam, you should check them out maybe every 12-15,000 miles.
Also, if you want to install something else at the same time, IMO titanium retainers would be a better investment than valves. But that's just my .02.
