Security Problem, Car won't Start. NEED HELP FAST!
***FIXED***Security Problem, Car won't Start!
Ok i went out to my car today and started it and it started fine. Went down the block and noticed the security light flashing so i pulled over to shut it off and figured the key may have been off a little. Went to start it and NOTHING. It doesn't crank or anything. Just sits there and fuel pump primes and all but nothing. What's wrong with the damn thing? A fuse maybe. THanks guys. It's my daily driver and i need it fixed~Cole~
check you rchip on you key it should read some resistance! that's what was bad on my key and another thing to try is use your another key if it works the chip on you key is bad thats what happend to my car.
Well i looked into my manual to see what i should be looking for. I noticed that when i get in the security light is FLASHING not just staying on. In the manual it says it's the key is faulty. I'm gonna look more at it in the morning when it's light out to see what i can figure out.
well update. I looked at the fuses and all the basic stuff and nothing is out of the ordinary. Took the key up to a local dealership that my dad happens to work for and one of the techs said he is sure it's the tumbler. He had a newer Camaro SS in there for the same thing and the same symptoms. Changed the tumbler and keys and all was good. He priced a tumbler and new key for $90 and another $25 if i want him to put them in for me on the side. What is your guys' input? He couldn't look at the car because it's not there and i can't get it up there today 'cause it's raining. but he is almost positive that's what it is. ~Cole~
Originally Posted by ColeTrains'96Z28
Well guys i got it fixed with the bypass. The car starts better then it did before too since i fixed it. Took me 20 minutes to do. Thanks for all the help~Cole~
