Sponsored by: DashLynx
Question about the stickers under the hood...
Old 09-02-2006, 12:38 PM
2000FormulaMan's Avatar
Default Question about the stickers under the hood...
I was wondering if the 2 stickers under the hood that are on the Drivers side wheel well, if they are really important and I shouldn't remove them? They are starting to peel as is and I just wanted to totally take them off. Are they important, do they HAVE to be there?
I was going to just take a picture of them before I took them off.
Thanks!
Old 09-02-2006, 01:12 PM
LS1_Disciple's Avatar
I took mine off and stuck them to some posterboard and put them in my glovebox. But they were pretty new. Not sure if you'll be able to get yours off in one piece. If you take a picture, you should be fine.
The car will still start with them removed
Old 09-02-2006, 01:31 PM
99zee's Avatar
I took a picture of mine and then peeled them off.
Old 09-02-2006, 02:57 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Im going to be photographing all of my underhood stickers and taking them off as well.
Old 09-02-2006, 03:58 PM
Well, I guess that answers that!
Thanks everyone!
Old 09-02-2006, 04:01 PM
Trev_SS's Avatar
hmm never really thought about taking mine off
Old 09-02-2006, 11:00 PM
99FormulaWs6's Avatar
I don't understand the photographing, I just took mine off.
Old 09-03-2006, 01:41 PM
LawmanSS's Avatar
I heated mine up gently with a heat gun, removed them, and stuck them to a sheet of paper...
Old 09-03-2006, 04:07 PM
99zee's Avatar
I took pictures just in case I needed the info at a later date. Mine had been on a while and came off in pieces.
Old 09-03-2006, 09:57 PM
HotWhipT/A's Avatar
My big sticker about the emmissions was weird. It cam off in one peiec, but it left a striped pattern on the car. It was the sticky part and the sticker was striped clear because that part of the ink was on the car. Its hard to explain, I'm sure i'm not the only one that that happened to. BTW, the sticky ink left comes off with Goo Gone really easy!
Old 09-04-2006, 02:33 AM
Duffster's Avatar
There are stickers under the hood???
Old 09-04-2006, 09:32 PM
LawmanSS's Avatar
That's completely normal...the sticker is intended to be tamper-proof. That's why you have to heat it up...the heat "bonds" the two layers together so that you can remove them together...
