Pics of Blue LED lighted interior
1 Post
Please post up your pics of your car at night with Blue LED's on the interior of your car if you have them please, planning on doing something similiar and wanted to just re-assure myself basically.
Also, any of you that've done this, Will the LED's at Advanced Auto Parts work fine for this? Or is it just gonna be a half-*** job if I use those? Also, what's the best way to wire them and have a switch for them? I want to keep my stocker interior lights but have these on the side for night driving so that I can have a little more light without have the interiors on constantly...
Thanks,
Caleb
Thanks,
Caleb
I just did the LED's in the door. Haven't gotten around to the rest of them yet.
You can see how bright the LED is shinning on my leg! lol I used the brightest led's I could get at RadioShack.
If youre asking me, it was simple, I just cut out the bulb then got a LED and a compatable resistor and wired them in place of the bulb. That goes for the switches too.
Originally Posted by Bad30th
Isn't the door-handle light already a LED ?
If not, what value resistor do I need ? The resistor wires in series to the (+) side of the LED, right ?
Rob (Bad30th)
Rob (Bad30th)
**non-sponsor link not permitted**
The source voltage should be 12v, might want to check with a meter to be sure.
Originally Posted by 1998TA__1991RS
do you have a link to how you did your car PC?? looks interesting
1 Post
Torchd 02 TA could you please post some more pics of yours where the bulbs are and etc?? Thats more of exactly what i'm wanting, the others are just too bright.
Thanks for all the pics guys,
Caleb
Caleb
Caleb
Caleb
those are the only pics that i have. i only replaced three lights. the 2 lights in the map lights.. (where the rear view mirror is) and the dome light in the back.. that is it!
the first is a comparrisioon of the LEDs Vs. stock amber lighting..
Thanks
Nope, its a cheezy little bulb. You can calculate your resistor with a LED calculator.
a sponsor sells a whole kit with the led's i believe check out the sponsor section.
her it goes...http://www.ledgauges.com/
