I have a question about bumpstops and tire shops.
Old 09-07-2006, 02:17 PM
Reznor's Avatar
Default I have a question about bumpstops and tire shops.
i have 11" ZR1's and they sometimes hit the bumpstops when i go over a bump too fast and the rear end comes down.
I want to get some drag radials mounted, and just curious if a tire shop like NTB or Discount Tire will be able to do the swap since you have to lift the car up from the differential to get the wheels on and off.
Also, would they be able to remove the bumpstops entirely?
Old 09-07-2006, 02:49 PM
SSilverSSurfer's Avatar
i doubt i know we wouldnt at our DTC, and i doubt they would do it at any other, why dont you jack up the car take the wheels to them and take the bumpstops off yourself? although i wouldnt take them off
Old 09-07-2006, 03:21 PM
Reznor's Avatar
did you have any problems with your wheels hitting them?
yea, i can do it myself, i just wanted to know if they'd be able to so i could just drive the car there and have them do it all at once.
instead of removing, what do you suggest? grinding? then i'd need more tools
Old 09-07-2006, 03:46 PM
bigun186's Avatar
I used to work at the discout on Bay Area Blvd, and we worked on cars like yours all day. I few of the guys that still work there drive camaro's and would have no problem doing the swap for ya.
Old 09-07-2006, 05:02 PM
Reznor's Avatar
that is actually where i got my tires. guess i'll head back there this saturday.
Old 09-07-2006, 08:41 PM
DONAIMIAN's Avatar
Not the best idea to remove the bump stops. It really beats the shocks up.
Old 09-07-2006, 09:25 PM
nickdotcom's Avatar
thats the one i work at
and i'll be working there all day saturday, we can either pull it into bay 0 or bay 8 and get it done no problem
Old 09-07-2006, 09:46 PM
sl0w's Avatar
I took out my bump stops, then went one step further and cut the mount out..... but that was to fit some 20"x11" Z06 wheels on the back....
Old 09-07-2006, 09:58 PM
Mustang Moderator
Stang Man's Avatar
If you jack it up from the bottom of the differential, the suspension will not move at all, so the wheels will not hit the bumpstops. Its when you lift the body up from the frame that you will have an issue with the wheel hitting the bumpstop.
Old 09-07-2006, 10:24 PM
01 Red WS6's Avatar
When I had my TT2s installed a few years ago the guy at Discount was willing to cut my bumpstops off. I told him just to unbolt the bumpstop. Once I got home I put them back in and pulled out the grinder and took care of the area that was hitting the wheel
