Head Studs won't thread in all the way...
Old 09-08-2006, 06:18 PM
Ferocity02's Avatar
Exclamation Head Studs won't thread in all the way...
Putting in my head studs, and I noticed a few on the driver's side won't thread in all the way. All of the studs on the passenger side stick out about 2.5", while a few on the driver's side stick up about 3". I can't imagine that there is anything in the threads, this block has been hot tanked and meticoulsly cleaned. So is this okay? or am I going to have to chase out the threads? Thanks!
Old 09-08-2006, 06:38 PM
67Firebird455's Avatar
My main studs wouldn't go all the way in... Chase the threads with a tap and put compressed air down the hole, should be golden...
Old 09-08-2006, 06:55 PM
Ferocity02's Avatar
I was told to not use a tap. Plus finding an M11x2.0 tap anywhere locally will be a nightmare. I'm using a ground down head bolt but it doesnt seem to be working. I think there is just a pile of junk smashed down in the very bottom of the hole. I'm trying to use a screwdriver to scrape it off the bottom.
Old 09-08-2006, 07:40 PM
89ws6formula50's Avatar
you need compressed air
Old 09-08-2006, 07:48 PM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default Cleaning threads
ARP sells a thread cleaning chaser 912-0011 for 11 mm x 2.0 pitch
Do not use a tap.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 09-08-2006, 08:03 PM
LS1Tech Sponsor
Slowhawk's Avatar
I just cut some groves in the stock bolt and use it as a chaser.
Old 09-08-2006, 08:20 PM
BlkHwk's Avatar
My block had a bunch of stuff in nearly all the head bolt holes. I turned the block upside down shot some brake clean in there and used compressed air to blow it out. On a couple of holes had to use a long screwdriver to break it up then breakclean and blow it out. Then used thread chaser.
Old 09-08-2006, 08:58 PM
Ferocity02's Avatar
Ok, I got them cleaned out. Here's what I did. I filled the holes with acetone and let it sit for 10 or so minutes to dissolve what loctite and **** was in there. Then with the acetone still in the hole I took a long sharpened flathead screwdriver and poked and twisted all of the crap off the bottom of the hole. I then blew out the holes with a compressed air nozzle with a long entension. What came out is best described as a compacted mud and sand mixture. I don't know how it got there, and frankly I don't want to know. Then I chased the threads with a grooved stock bolt followed by more compressed air. Now all of the studs are sitting at the same height
Old 09-08-2006, 09:28 PM
Beast96Z's Avatar
There were head studs in it when I got it and all were fine. I hope your hot tank guy dosen't have a "sand cleaning" cycle.
Old 09-08-2006, 09:35 PM
Ferocity02's Avatar
By hot tank, I meant it got done at Katech, I'd imagine. The only cleaning I did was a good old cleaning with a sponge and a hose in the driveway. Well... sponge, tube scrubbers, 5 different kinds of cleaners, and two hours
Quick Reply: Head Studs won't thread in all the way...
