Need to get cats on my car for inspection- need suggestions on good flowing cats
I moved to NC and there is inspection here. Safety and OBD is all they check, there is no sniffer test but I won't pass with an OR Y as it is 'if' they do a visual on the exhaust.
Does anyone have suggestions one good flowing cats? I can buy a Mac Y with cats, but I've heard they don't flow that good.
Open to any suggestions on aftermarket cats, welding some high flow cats won't be a problem into the current ORY.
Thanks,
Claire
Thanks,
Claire
i would buy some cheap cheap cats, from summit or something, . . gut them out and slide your exhaust tubing through them, . . that way it'll look as if you have cats but they wont be functional, . . i will be doin that soon, . . pros of each: beat visual inspection, save money, more flow vs. beat visual , spend alot of money, and less flow, . . . .. . . . . . . . . . .
Well, I guess we'll figure it out. I wouldn't mind having to buy some Kooks LT's with cat either but that's not gonna happen!
Thanks guys, I will have to check into some cheap **** thru Summit or Jegs and see about getting then welded in for looks anyway
Picked up my dynatechs from summit. They're somewhat cheaper, are very compact, flow pretty well, and are OBDII certified so you get the best of every world. And just for reference I have a 408 setup with an LS6 intake/ported tb that made 475/450 through these on a mustang dyno.
