what is the biggest you can take a 6.0l block?
Old 09-11-2006, 04:40 PM
Chris Gage's Avatar
Default what is the biggest you can take a 6.0l block?
While using the stock crank??? The block being used is a LQ4/LQ9
Old 09-11-2006, 07:17 PM
Black Sunshine/ 00SS's Avatar
30 over, and 60 if you sonic check the block & it comes out good.
Old 09-11-2006, 08:22 PM
Chris Gage's Avatar
what size i meant....
Old 09-11-2006, 11:54 PM
Nate_Taufer's Avatar
You could make it a 376 with a 4.06" bore. I wouldn't push it past that although some have gone as high as 4.08"
Nate
Old 09-12-2006, 03:54 AM
PREDATOR-Z's Avatar
Nate
What he said
Old 09-12-2006, 04:45 PM
8banger's Avatar
With a 4" crank, a 4.03" bore would get you a 408, and a 4.06" is a 414.
Old 09-12-2006, 05:39 PM
dug
dug's Avatar
What size bore do you need for the LS7 heads? Is it unrealistic to expect 600rwhp with those heads on a 414? Whats the longest stroke you can run? 4.125"?
Old 09-12-2006, 07:07 PM
8banger's Avatar
4.125" is the longest I've ever heard of. I heard that the LS7 heads work best with a 4.1" or bigger bore, however the L92's are basically the same heads, unported, and they come stock on a motor with a 4.03" bore, so I think the LS7's could work on a 414. With a good port job, good intake, decent compression, and an appropriately designed cam, it should be close to 600rwhp if not over. After all those heads (L92's, not even LS7's) flow 330cfm stock.
Old 09-12-2006, 11:34 PM
Jed Z06's Avatar
I am bulding up a 415ci
6.0l bored 4.0625 x 4.0 stroke
block was sonic tested by HPE
Old 09-13-2006, 10:13 PM
BOTTLEFEDLS1Z's Avatar
Is Eric K. doing the work for ya???
Old 09-14-2006, 11:04 AM
Jed Z06's Avatar
Yes, this block was initially built by him~
