Added some underhood bling and picked up 2psi...
Old 09-12-2006, 10:13 PM
chriswtx's Avatar
Default Added some underhood bling and picked up 2psi...
So, I added a new intake manifold and side brake ducts. Couple of hours to do the intake and 16 hours on the brake ducts. Think it makes the car look much better... Picked up 2psi of boost. So either I had a hose clamp leaking or a leak on the LS6 intake somewhere. Car feels much faster though..
Old 09-12-2006, 10:20 PM
NKAWTG...N
StoleIt's Avatar
wow that looks awsome! kinda like a z06 duct, but not...
Old 09-12-2006, 10:41 PM
navymitch12's Avatar
looks great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-12-2006, 10:44 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
The ducts look really good. Do you have a pic from the front aiming towards the back that shows how far they extend out?
Old 09-12-2006, 10:46 PM
SS4Matt's Avatar
do i see the splitter of a yellow C6 Zo6 in the background of the first pic???!!!
car looks kick ***!!!
Old 09-12-2006, 11:31 PM
patriotformula's Avatar
thats a bad *** car man... are those brake ducts custom or some kit molded in on your own?
Old 09-13-2006, 09:11 AM
chriswtx's Avatar
Yeah, 2006 Z06 belongs to my friend John. Not very fast though
Old 09-13-2006, 09:13 AM
chriswtx's Avatar
They are a kit from breathless performance that are ment to be stuck on. Instead I ground down the lip and glassed them in smooth.
They do stick out. Its just right. About the same as the tires so it looks real good...
Old 09-13-2006, 03:53 PM
SS4Matt's Avatar
damn i'm good
Old 09-13-2006, 03:58 PM
Tiago's Avatar
you sure that new manifold isn't more restrictive? j/k
looks great!!
Old 09-14-2006, 02:44 PM
Import Patrol
CrawlinWS6's Avatar
looks good!
Old 09-14-2006, 04:47 PM
Rickys S/C Z28's Avatar
well iv been wanting to see the intake on a car and now im going to buy one looks great
Old 09-14-2006, 06:02 PM
Hennytime's Avatar
is that the new manifold from bynuspeed?
Old 09-14-2006, 06:16 PM
chriswtx's Avatar
No, its a Weiand polished intake. If any of you decide to get one, you need to know a few things that arn't in the instructions. When you remove your old intake you need to take a dremel and grind all the round sides of the head bolts flat with the head surface. They stick out just a little and the intake will not sit flat and you will get a vaccum leak. Aslo grind a little off the tops of the valley bolts and if you have the LS6 PVC sticking up you need to clearence it a little as well. First time I installed it I had a bad vaccum leak. You also need to add a little sealant around the MAP sensor seal on a boosted car. The whole they have is a little big...No big deal. Nothing new for a modded car...
Old 09-14-2006, 06:58 PM
~JOSHUA's Avatar
I've got that intake too. Pimp. ~Joshua
Old 09-14-2006, 07:04 PM
Lafngas98Z's Avatar
looks great!!
Thats what I was thinking, could explain the 2psi increase?
Old 09-14-2006, 07:06 PM
chriswtx's Avatar
No its not more restrictive. Once you have it in you hands and can compare the two side by side you can see how well its designed...
Old 09-14-2006, 09:43 PM
~JOSHUA's Avatar
Yeah... it's not bad, but I'd still like to send mine off to get an "extrude hone" process done. Then it would be perfect.
Old 09-14-2006, 09:53 PM
chriswtx's Avatar
Thats an idea. I was going to hand port mine when I finish building my new forged motor. Just a light clean up then squeeze 16psi through it..
Old 09-15-2006, 09:57 PM
Lafngas98Z's Avatar
You can "see" that is more or less efficient? My comment was not intended to hurt your feelings but how else would you explain picking up 2psi?
Quick Reply: Added some underhood bling and picked up 2psi...
