What is the difference in these cams
I ordered a cam from TSP set up as follows 220/222 @050 581/581 lift 114 lobe sep. centerline 110 +4
They sent me 220/222 @050 581/581 lift 110 lobe sep. 106 centerline
What will be the idle and performance difference. need help quick before I send the cam back.
It actualy is a good torquer cam, 1* overlap
These are the VE's
0.050
220
222
110> LSA
106>ICL
4>IVO
36>IVC
45>EVO
-3>EVC
114>ECL
1>overlap
It will peak very early like 5700/5800 and with 45 EVO make a Sh*tload of trq at mid/low range. It will be very peaky with shiftpoints around 6100
These are the VE's
0.050
220
222
110> LSA
106>ICL
4>IVO
36>IVC
45>EVO
-3>EVC
114>ECL
1>overlap
predator Z you are good man I beleive you peaked the cam card. How bad will the lope be on this cam I wanted to kinda stay on the stealth side of things and good idle quality for a DD
