~Custom Rear Mount HELP~
Ok well I think I have just about enough money to complete this entire kit....
Keep in mind this is a street and OCCASIONAL track car....
Now my goal is to have a set up that spools pretty quick at or below 3000rpms (preferably below) and make around 500rwhp at around 5psi (if possible) with a custom rear mount setup. With the option of turning it up to around 600-650rwhp.
Heres what I had in mind....and if anyone can help with the ones im not sure of PLEASE DO!
t67 turbo (dono what ar)
6.0 Heads (anything better? what gain will i see?)
z06 Camshaft (anything better? what gain will i see?)
Spec 3 clutch
TiAL BOV (dono 9psi? 11psi?)
Wastegate (not sure which is a good one)
42lb Mototron injectors (should i go bigger?)
255lph Walbro fuel pump
valve springs (not sure which ones)
pushrods (not sure which ones)
Ebay Intercooler w/ 3" piping
Tilton Differential Pump
2.25" piping from turbo to MAF
Anything I missed? Any suggestions??
Oh and i plan doing the rear end and building the block very soon afterwards.
Spec 3 clutch
You have the list close... I would add upgraded Oil pump, upgraded (racetronix like) fuel harness and 60lb injectors. Also do a search on the Spec stage 3... I think it will give you problems. I like the Ram HD.
I would sell you my LPE GT-7 Cam if you havent already purchased one.... great for what you are doing.
For springs I would go with Pat Golds (I think Billy is having a special on them)...
I dono....it seems like this is an easier way to do it....and I guess if you consider about $5k budget, then yes. This is the way I look at it....I might as well do everything right the FIRST time and take a little bit longer building it then buy cheap stuff and have it quickly.
