YSi head unit mounting question
Old 09-15-2006, 07:19 AM
rufretic's Avatar
Default YSi head unit mounting question
Can it be mounted in the same spot as the standard vortech kit? I plan on keeping my stock air lid location so the vortech comes with a pretty nice set-up for this. Then I'd like to do some cusom plumbing to a fmi. Right now my only option seems to be the vortech kit but I want the larger YSi unit. Any other options you guys can think of? I like the D1SC also but I don't like where it mounts.
Old 09-15-2006, 07:29 AM
Got Me SOM's Avatar
yes but you need to buy the bracket from RMCR. The G trim bracket will not work.
Contact Speed Inc they sell a YSi kit with a front mount, you'll have to custom fab the piping which anybody can do for ya.
Hope you have a forged bottom end and a good set of valvesprings.
good luck and let me know how it goes, its my goal to upgrade to a YSi.
Old 09-15-2006, 09:58 AM
CHRISPY's Avatar
Does the RGR bracket allow you to use the stock SS hood without butchering it? Stock fans still in place?
Old 09-15-2006, 10:09 AM
Got Me SOM's Avatar
RGR bracket?
You have to clearance the hood for the G trim, so you would probably have to notch a little more or run a different hood. The YSi is a much bigger unit.
gives you a chance to run a more aggressive looking hood, that's the way i look at it.
stock fans are retained.
Old 09-15-2006, 10:51 AM
CHRISPY's Avatar
Thanks man, Sorry I mean RMCR not RGR.
Old 09-15-2006, 10:58 AM
ss1
ss1's Avatar
If the search was working you'd probably find some useful info from the past couple of years. I did quite a bit of research a couple of weeks ago before acquiring my new T-Trim. From what I found, the YSi has a larger diameter outlet, and is going to sit higher than the G & T-trim. If I remember correctly, from what I read, the YSi will not fit in the same location without modifying the hood on a Camaro. Not sure about your T/A, you might be ok.
Old 09-15-2006, 11:15 AM
2001WS6Vert's Avatar
I am having RMCR do a custom intake system for me. I should get it next week. It will use a 4" intake designed for no MAF (currently on pressure side). The air box lid is made to match out of metal with the intake coming into the corner (like the Spectacle Solutions lid). They say I will have to cut into the hood (between the Ram Air humps) so the YSi outlet tube will fit. They also said I would have to relocate at least the #1 coil. I got the Thunder Racing wire relocation kit. They also had me send my power steering pump in (don't know exactly why). I run a FMIC which you can see in my sig. link when it had the T-trim. I do plan to eventually weld the cold tubing so I don't have so many silicone connectors.
Old 09-15-2006, 01:26 PM
Got Me SOM's Avatar
hmm RMCR made no mention that the #1 coil would have to be relocated.
Old 09-15-2006, 01:32 PM
Got Me SOM's Avatar
Old 09-16-2006, 09:23 AM
JMBLOWNWS6's Avatar
Looks like mine And Inspector 12 sent me the spec sol lid and I didnt gain ****. Im not sure if the motor was allready hurt or not but we will see this round. Ill try it one more time if not Im going to send it back to him. #1 Coil pack WILL not clear with the YSI on the T trim bracket. I am 100% sure of it. You will have to relocate it farther down or out of the way. And the hood will have to be notched. Theres barley enuff room for my T trim much less a monster YSI! With a ram air hood!
Old 09-16-2006, 09:45 AM
Got Me SOM's Avatar
JM you selll that T trim? Ever get it to the track with it on? How come you switched to turbo so fast, more potential to make more powah?
Old 09-16-2006, 09:50 AM
JMBLOWNWS6's Avatar
I have it still bro! Going to start her up Friday of next week. I got most of it all assemblied but my wife got sick I talked to Dalton and he gave me a smokin deal. Im just waiting on the guy who is buying it to come up with all the $. And he has one week left. If not Im going to put it up for sale. It is a fun kit but Im really was looking for more power. I can still make more with this kit remember thats with a 2.95 pulley and 11 psi We will see what she will put down thru the 4l80 by next week. If I still have the kit.
Old 09-16-2006, 09:59 AM
rufretic's Avatar
Great info guys, looks like I have a few more things to add to the list.
Thanks,
Lou
Old 09-16-2006, 10:51 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I ran the custom YSi Speed Inc./SS Racing kit. It placed the YSi blower down where the alternator would normally be.
I would not run the stock Vortech aftercooler with the YSi.
Old 09-16-2006, 11:02 AM
Got Me SOM's Avatar
just curious how much would you sell it for? Think all I would need is the bracket and the compressor right? let me know
pm me if you want
and definitely run it with the blower before you change setups to see how much of a difference it makes.
Old 09-16-2006, 11:38 AM
JMBLOWNWS6's Avatar
I would sell the WHOLE kit for no less than $4750 shipped! Im going to run it before I sell it. LOL
Old 09-16-2006, 11:50 AM
Got Me SOM's Avatar
what does the WHOLE kit consist of?
Old 09-16-2006, 11:51 AM
JMBLOWNWS6's Avatar
LOL Complete vortech kit
Old 09-16-2006, 11:53 AM
I was thinking about using the ice chest and water pump from the race car and plumbing it back to the aftercooler to see what results I might get since I have the parts anyway. I did initially loose three lbs. boost going to the front mount. I'm thinking the aftercooler might still work well if it had a real high flow of ice water through it. I really don't think it's all that restrictive even though it does neck down to a 2 1/2 inlet. The guys at RMCR were talking about fabbing up a 3" inlet side for the cooler, I'm not sure if the've done it on a car yet though.
Old 09-16-2006, 11:56 AM
Got Me SOM's Avatar
i'm not going on too much sleep
I just need the bracket and compressor. wonder if rmcr would just sell me that. I want more powah.
Quick Reply: YSi head unit mounting question
