GM high volume oil pump or Melling ?
Old 09-15-2006, 01:14 PM
csmc711's Avatar
Default GM high volume oil pump or Melling ?
Just wondering which I should go with if given the choice? Can I use an after market timing chain with either?
Old 09-15-2006, 01:52 PM
jdoyle's Avatar
mellings here with rollmaster double non adj.
Old 09-15-2006, 06:47 PM
BlkHwk's Avatar
I am running the melling with rollmaster dual roller adjustable. I haven't fired the engine yet hopefully next week.
Old 09-15-2006, 11:16 PM
Insanekamel's Avatar
thats what im running and i love it.
Old 09-15-2006, 11:37 PM
BlkHwk's Avatar
If you run the dual roller you may have to do some clearancing on the timing cover. I know I did on mine. I am pretty sure you have to on the LS6 pumps also but never ran it with the LS6 pump. GL
Old 09-16-2006, 08:32 AM
MiaSSmaro98's Avatar
havent heard of clearing the cover when using an ls6 pump
Old 09-16-2006, 09:04 AM
JMBLOWNWS6's Avatar
You will be fine. Im running the same setup with my double roller and a ATI balancer kit for my vortech.
Old 09-17-2006, 07:34 PM
csmc711's Avatar
What about the Lingenfelter pumps? Seems I am coming across them now in my searches also?
Old 09-18-2006, 08:43 AM
Killer_Bluebird's Avatar
I used a TSP ported one with a Rollermaster Double roller. It works great I get about 60psi @ iddle when the engine is warmed up.
Old 09-18-2006, 10:22 AM
n2o
n2o's Avatar
Melling did not do for me. Going with a ported ls6.
Old 09-18-2006, 10:48 AM
csmc711's Avatar
Melling seems like the #1 unit to have, what did it not do for you n2o ??
Old 09-18-2006, 12:02 PM
damn 60 psi at idle so what do u have at wot?
Old 09-18-2006, 01:20 PM
n2o
n2o's Avatar
Make enough pressure. Then it eventually dropped to zero. Had another car here nearby that had one. It was a turbo car, and it was ugly.
Old 09-18-2006, 01:50 PM
pekkaz's Avatar
Was it a stuck pressure relief valve ?
Old 09-18-2006, 02:22 PM
Cop Car's Avatar
ported LS6 and LS2 chain, proven, bulletproof and cheap. (its about $200 for the pump and chain)
Old 09-18-2006, 04:35 PM
I'll run a Log tonite to be specific but is up there at wot.
Old 09-18-2006, 08:46 PM
csmc711's Avatar
Really n20? Thats a bit odd, going to -0- ?? I would not think it would go to 0 unless you had something like 3" bearing clearances....hmmmm???
Anyone know what the Lingenfelter pumps are? Are they ported LS6 pumps?
Old 09-20-2006, 02:12 AM
OK here are my numbers with the TSP Ported Oil Pump. I was mistaken. Pressure is 60# cold @ iddle when the engine is fully Hot it drops between 45-50# @ idle. Cruising around at 2k rpm it goes back to 60# at wot it is about 75# at ~5,500-6k rpms.
Old 09-20-2006, 08:00 AM
awesome i order mines already
Quick Reply: GM high volume oil pump or Melling ?
