Drag Racing Tech - 27inch tire,411 gear,a4,will this work?
SPRAYED 01
09-18-2006, 05:20 PM
Im converting to an a4 with 4000stall. Will a 27inch tire work for low10s at about 128-130mph. Is there any kind of mods to the rear fender for the 27s?
SPRAYED 01
09-18-2006, 10:01 PM
Anyone???
WARDLAW `02 Z
09-19-2006, 06:31 AM
Not sure how the combo will work on the hose. I ran a 4400 stall w/4.11's and a 27" Hoosier QTP. It was just a H/C car and was good for 11.30's @ 118 Didn't have to cut anything to get the 27's to fit, just message the inner fenders a little. Adj. PHR and LCA's will help tuck 'em in.
Pro Stock John
09-19-2006, 09:31 AM
I think the 27's will fit without needing any clearancing. As an example I ran 28x9x15 ET Drags on 15x8's back in 2000 and they did not require any bodywork.
But you'll have to see if the rpms get a little high. I'd just spray 150 and see what happens, maybe have the spray shut off at 6600 rpms?
JL ws-6
09-19-2006, 11:20 AM
27x11.5 qtp fits without any clearancing at all, I've sen a few people put htem on, myself included without any mod's for clearance at all.
I have a 5000 converter and a th400 with 4.10 gearing, with the 27 inch tire, I think it should be o.k. to about 10.30@130 if I spin the motor to about 7000, anymore then that and I'm gonna need a gear change/tire height increase, at least that's what it figured to when I was doing the calculations.
AL SS590 M6
09-20-2006, 07:33 AM
I'm running 27" QTPs with 4.10s and a Yank PT4000. I run 11.2x @ 119+ and I'm going thru the traps at 64-6500. No way could I trap 130 mph without a taller tire or less gear.
JL ws-6
09-20-2006, 08:33 AM
I'm running a 5000 converter and 130 won't be a problem.. all depends on converter slip. Of course if you want to keep the rpm's in the 6500 range you'll need a change, but refigure it if you spin to 7000 at the end of the track, 130 is alot closer then you think.
AL SS590 M6
09-24-2006, 07:03 AM
I'm not spinning my stock bottom end to 7000rpm.
JL ws-6
09-24-2006, 09:38 AM
smokin01ta has been spinning his well past that point, maybe he will chime in on this
TwoFast4Lv
09-24-2006, 10:18 AM
They fit fine. I am trapping 135+ and going through the traps at 7,000+ with 3.73s ;)
Packy
09-24-2006, 10:31 AM
27x11.5x15 qtp's fit my car just fine. I had to massage the inner fenders slightly but not a whole lot. I usually run mid to low 11's at 125 or so with a stock t-56 and 3.73's. I still have plenty of rpms left though. Soon when I crank up the boost though I am sure I will be pushing around 6600 through the traps.
