Alt relo bracket and aftermarket fuel rails?
Senior Member
Anyone have the SmokinHawk bracket and aftermarket rails/ regulator? I got the bracket mounted and the alt. aint even coming close to fitting I have to have the fitting for the return, but tit seems the only way itll fit is without the 90* fitting and NPT adapter.
Its always one thing after another.
Senior Member
I have a bolt in the bottom hole so thats why it looks cocked to one side. The bolt is holding it in place. The bracket isnt bent at all. This sucks too,I needed it running this weekend This is the only thing stopping me.
what rails are those?
thats strange cause i test fitted it on my car with the speed inc rails. somethings up though.
can you tighten that npt thread any tighter to get it closer to the rail?
some have cut the rail a little bit. that would be your best bet on getting it running this week end, cut some off then get the right npt tap (if you need it to push the threads back)
Senior Member
They are the Speed Inc rails. The NPT fitting is as tight as I could get it without ripping the rail off the intake. It wont go any farther. I dont think cutting the rail is an option. I have nothing to make a perfect cut with, nor do I have a 3/8 NPT tap. Plus, it doesnt look like I could cut enough off without interfering with the injector.
KH, no shorter fitting. The alt just wont fit.
Would a fitting like this work? Not sure how much extra room you are needing?
http://store.summitracing.com/partde...5&autoview=sku
