Calling all 383 LT1 vortech supercharger guys!
Old 09-20-2006, 10:27 PM
frbrd7996's Avatar
Unhappy Calling all 383 LT1 vortech supercharger guys!
I have just finished my 96-M6- 383-LT1 with basic votech kit 6-8 lbs.I have the Loyed Elliot stage 2 head/intake port to match 52mill throttlebody,and eagle 3.75 /5.7 rods.Pcmforless mail order tune,LT4 knock md,msd 10 mill wires,tr6 plugs,cloyes double roller timming chain,1.6 rr all the goodies.The eagle stroker kit that I bought I paid extra $$ for internally balanced.Srp dished pishtons too.Passesetter long tubes/with exhaust no catsI have stock balancer,and stock flywheel on this.I have to get my cam card for the specs but I know it is a comp cam with a 576/lift.
It started right up and sounds badass.When I started driving this there is a vibration in this that kind of scares me and some other people.I have put 45 miles on this,and it runs really sloppy/bad/not smooth/up and down with speed.
Does anyone with a 383 supercharger have an aftermarket balancer that works with the pulley from vortech?Does anybody also know if I should get that flywheel neturally balanced/b/c this may becausing the vibration?I need some help car has been sitting since first notice of the vibration.
Old 09-20-2006, 10:54 PM
94z28L's Avatar
may want to check the tune, it may be off if its running sloppy
Old 09-21-2006, 08:33 AM
383ysi's Avatar
is it your stock flywheel, did they balance flywheel w/motor
Old 09-21-2006, 08:51 AM
RealQuick's Avatar
You need a nuetral balanced flywheel if they internally balanced the rotating assy. If they balanced the rotating assy without the stock flywhel and damper, then you must have a zero balanced flywheel... the stock flywheel IS balanced (weighted) and isnt the right one to use.
Old 09-21-2006, 04:00 PM
frbrd7996's Avatar
Is the stock balancer ok to use?
Old 09-21-2006, 09:08 PM
engineermike's Avatar
The '86 to '97 "internally balanced" chevy v-8's weren't truly internally balanced. They were internally balanced in the front (unlike a 400 SBC) but not in the rear. Alot of people are confused by this. I bought an Eagle 3.75" crank that was internally balanced. I fully expected to use the stock 1-pc rear seal flexplate because it's for an internally balanced chevy, though it has a counterbalance weight. When balancing, we found that simply removing this weight balanced it perfectly. Now, it is a TRUE internal balance, as in, both the flex plate and balancer are neutral.
Mike
Old 09-22-2006, 07:47 AM
RealQuick's Avatar
yes
Old 09-22-2006, 08:59 AM
Not with the Vortech pulley. It won't mate up right.
Old 09-22-2006, 09:01 AM
RealQuick's Avatar
I thought the vortech pulley bolts to the stock crank pulley (thats what it said with the S tirm kit I had)?
Old 09-22-2006, 10:58 AM
The front surface on the stock pulley is cast and not very uniform. Not sure when, but Vortech started supplying balancers with their kits with the front machined into a smooth, true surface.
Old 09-22-2006, 11:03 AM
jldak318's Avatar
Mike
im glad u brought this up, i was wondering about this the other day. so all i have to do is take off the weight right?
Old 09-22-2006, 07:18 PM
frbrd7996's Avatar
Default How much power do you think?
That 383 supercharged LT1.How much should it make with a good dyno?
Old 09-22-2006, 08:10 PM
I got lucky. The piston weight can throw things off quite a bit. Pistons can be anywhere from 350 to 700 grams, so I wouldn't do anything without spinning it up on a balance machine.
Mike
Old 09-23-2006, 11:56 AM
Funkybird's Avatar
I had the same pfoblem with my new engine. I had the weights removed from my flywheel and then balanced to zero and that fixed the vibration.
Quick Reply: Calling all 383 LT1 vortech supercharger guys!
