Who grinds custom cams?
Moderator
Originally Posted by PREDATOR-Z
Comp does the same if you request it, they all do>
I was under the impression comp wants big money to grind a cam based on your valve events if they don't have a lobe that matches your request. IE making you a custom lobe. I think Elgin and the other cam MFG do it a lot less.
I get mine from TSP for the same price as they offshelf cams $ 369.00
Grinding to custom VE and designing a lobe are 2 different things. of course grinding to a custom lobe will cost more. But custom VE's on actual market lobes are not expensive.
I called Thunder and told them exactly what I wanted. They placed the order to Comp and a week or two later I had my custom cam, at no additional charge. I think anyone could call Comp directly and order a cam FWIW.
