Drag Racing Tech - Is runnin spray safe on the LT1
racing_junky
09-23-2006, 02:24 PM
im in the process of finding a LT1 and i wanna run 12's.i noticed alot of people r running nitrous.so my question is how much can that motor handle before blowin up if u run nitrous?
94z28L
09-23-2006, 02:30 PM
you can usually run a 100 wet shot safe with out major changes, just make sure you're runnin a window switch, WOT switch and some other safety measures, on some of my earlier posts i asked about the same thing in the nitrous forum if you check my older posts
tektrans
09-23-2006, 05:15 PM
Spray is never safe, IMO. Sure can be fun though:)
1QuickT-A
09-23-2006, 05:35 PM
nitrous is safe on a fuckin lawnmower if you know what you are doing and use it correctly..
Agree. Just be aware of the increased cylinder pressures with Nitrous. If you have a high-mileage motor with stock rings... it'll find the weak spot quick.
The other problem is on LT1's the back 2 cylinders can go a little lean due to the construction of the LT1 and LT4 intake manifolds. I had some evidence of detonation on my #7 plug after making a couple 100-shot passes the other day.
TwoFast4Lv
09-24-2006, 10:13 AM
N2O can be safe. I have ran it for years. stock motor, bolts,H/C and now bored and stroked ;)
Here is the latest run (http://www.rkarasek.com/video/SSEFI%2010059.wmv)
Number eight definately runs leaner unless you find a way to richen it up ;)
roadtrip120
09-26-2006, 01:51 AM
Sprayed the 200 shot off a stand alone a few times just for money races.
150 all day long
TwoFast4Lv
09-27-2006, 09:11 AM
we bumped to a 200 shot and sprayed the hell out of it ;)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
