Wrapping hot parts
Wrapping hot parts
Does anyone have any before and after results with wrapping their hotparts? How about a turbo blanket? Any difference in spool time? Any difference with under hood temps? Would it be benneficial to wrap the headers too even if they are ceramic coated or would just the crossover be enough. Lets hear some opinions.
I let my friend borrow my turbo blanketand he said he couldn't really tell a difference in spool time. But he sees 8 spi in a heartbeat with his stalled TH400 and a T76. I'm sure it helps A LITTLE in under hood temps, but he hasn't measured.
FWIW: I am getting my hot parts ceramakrome coated, and wrapping all of them...and the first half of my DP. And of course snatching my blanket back from my buddy. I'm not fauxin around.
I can tell you wrapping my crossover I picked up almost 3 psi of boost, no WG changes. It also made a drastic difference in radiated heat. I can touch my hand on the crossover immediately after shutting the car off and not get burned.
I don't have much data on coatings, but I believe if you car wrap some hot part it would be better than coating.
Originally Posted by longrange4u
Hmmm heard mixed opinions about coating and wrapping... I think if you wrap you will cook off the coating.
So wrapping over the coating and then driving with it = rust and ceramic breakdown, pretty quickly.
Over uncoated mild or stainless tubing the wrap works great.
The wrap is also very useful for sound control on your whole system. Damps any ring and a lot of the high-frequency exhaust tones.
There are good wrap pix (over mild steel exhaust, mufflers) and a couple tips at my site, 3/4 down.
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Wrapping lowers your underhood temperatures by trapping the heat near your wrapped part. Some people have problems with this because the heat of the wrapped part increases enough to burn off protective coatings. (hence exposing bare areas to moisture and creating rust and such)
I suppose if your wrapped parts (like your headers) can take it, then you could do it.
I personally wouldn't put this on my car, but don't listen to me; I drive a drinky little import around
It's give and take
It's give and take
Found this on another forum. I think the underhood temps would be more important to me. What do you think besides the fact he needs to learn how to spell?
" Wraping is well worth the effort and can produce HP for sure. Although even though it keeps heat of the engine bay wraping the Downpipe it can hurt performance, everything else it helps. The turbo works from a pressure diffarental across the turbin wheel, Hot gas on one side and cooler gas on the other is what makes it turn. For best performance you want to keep it as hot as possible before the turbo & cool it off right after it leaves the turbo and this makes the most defferance between the pressure on each side to give the best performance out of the turbo(quicker spool higher boost ability) . You have turbulance after it leaves the turbo so you want to keep the pipe the same size it comes out of the turbo for about 2" to 10" so that the gas gets strighten out and flows smoothly. Then you can expand the pipe to a larger size & this expantion helps cool the gasses to help with the pressure between pre & post turbo. But if under hood temps are extreem and the DP needs wraped just to help this problem out its not like it kills HP it just can make more power by leaving it uncovered to let it cool."
Oh yes, and I agree that he could learn to spell better.
