600 hp
Old 09-27-2006, 02:48 PM
camaro ss02's Avatar
Smile 600 hp
ok i have a 02 ss and it has 30k on it i have cold air intake exhast throttle body mas and 100 shotn i want to build 600 hp what do u all think i would newed to get there????
Old 09-27-2006, 03:09 PM
jmm98LS1's Avatar
Originally Posted by camaro ss02
...i want to build 600 hp what do u all think i would newed to get there????
money....lots of it.
Old 09-27-2006, 03:11 PM
transamfreak01's Avatar
its gonna be really hard gettin there on stock cubes... go bigger or f/i w/ spray...
just my 2 cents
Old 09-27-2006, 03:12 PM
NVR KNO's Avatar
you could get about 10k for a turbo kit and then maybe another 2 or 3k to forge your internals. you could then get 600hp. but then you have to worry about your rearend handling it and also your tranny, cause they wont hold it for long. like jmm98LS1 said, lots of money.
Old 09-27-2006, 03:19 PM
WhiteKnight98TA's Avatar
build a bullet proof forged to all hell 347 - moderate H / C
slap 300 shot wet kit on.
hang on for dear life.
Old 09-27-2006, 04:36 PM
NightWindDriftr's Avatar
F/I and supporting mods is calling your name.
Old 09-27-2006, 04:42 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
lol.. seriously!
Old 09-27-2006, 04:51 PM
Administrator
unit213's Avatar
Old 09-27-2006, 04:52 PM
SaultysHuggerSS's Avatar
To do it right you need bout 7000 $ Cash.
Get a built rear end Built Tranny perfered with trans brake.
Then you will have to bore to a 383ci
Get forged eagle crank , Forged rods and pistons , Set of AFR heads , Cam ,Fast 90/90 Setup. Headers .
F1 Procharger INtercooled.
Then you might want to get bigger injectors bigger fuel pump
And a nice tune.
Then if you want to go any where you might want to get some 11 in rims run MT street ET's 315 , torque arm ,subframe connectors, Panhard bar,sway bars ,Lca Relocatoring brakets,Lowwer control arms ,Set of sa koni struts
That Should be more then enough to get 600 horse.
Or i guess you could Get full bolt ons have a tune and run bout DP 200 shot .
Wouldnt last long but would be a wicked ride.
Old 09-27-2006, 05:12 PM
BrandonDrecksage's Avatar
Originally Posted by unit213
x10 and lots of research. n/a won't happen. you need fi or lots of n2o
